  • B&C DCX354-8 1.4" Neodymium Coaxial Compression Driver 8 Ohm 4-Bolt
B&C SpeakersPart # 294-6464
Model: DCX3548
Modern speaker arrays demand closer source spacing, higher output, and lighter weight. To meet this continuing challenge, B&C Speakers introduces the DCX354-8 coaxial ring radiator. A more compact sibling of our groundbreaking DCX464, this driver offers remarkable performance with minimal compromises, making it an ideal choice for advanced audio systems.
  • 1.4" neodymium coaxial compression driver with 8 ohm impedance
  • Midrange diaphragm covers 400Hz – 6kHz with 111.1 dB sensitivity
  • High-frequency diaphragm covers 5kHz – 20kHz with 112.8 dB sensitivity
  • Midrange 76mm (3 inch) voice coil handles 180 watts
  • High-frequency 51mm (2 inch) voice coil handles 100 watts
  • Patented midrange integrator for seamless diaphragm performance
  • Advanced diaphragm shape for extended low-frequency bandwidth
Your Price: $590.70
Save $393.80 (40%)
We'll send you an email when B&C DCX354-8 1.4" Neodymium Coaxial Compression Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
Estimated back in stock 10/30/2026
The DCX354-8 features a midrange diaphragm that covers 400Hz to 6kHz with 111.1 dB sensitivity, powered by a 76mm (3 inch) voice coil capable of handling 180 watts. The patent-pending diaphragm shape progressively decouples the outer diameter as frequency rises, extending low-frequency bandwidth. Complementing this, the high-frequency diaphragm spans 5kHz to 20kHz with 112.8 dB sensitivity, driven by a 51mm (2 inch) voice coil that handles 100 watts.
A redesigned, patented midrange integrator ensures that both diaphragms operate harmoniously over a broad bandwidth, enhancing combined output and crossover flexibility. This sophisticated design results in a powerful yet compact 1.4” throat driver that delivers un-fatiguing sound at unprecedented levels.
To create more than just a smaller version of an existing product, B&C Speakers employed new mathematic modeling techniques, pioneering a method to evaluate dozens of potential diaphragm shapes in a single day. Extensive field experience and customer testing led to numerous improvements and redesigns, ensuring the DCX354-8 meets the rigorous demands of modern audio professionals.
BrandB&C Speakers
ModelDCX3548
Part Number294-6464
UPC8050593406538
Weight5.55
Diaphragm MaterialPoly / Mylar
Exit Diameter1.4"
Mounting Type4-Bolt
Power Handling (RMS)180 Watts
