  • 12V AC/DC Incandescent 4mm Grain of Wheat Panel Lamp with Insulated Leads
Parts ExpressPart # 070-107
Rejuvenate your vintage stereo receivers with the original look of incandescent lights using this 12V indicator lamp. It also replaces burned out bulbs in vehicle instrument panels.
  • Popular in vintage Marantz, Sansui, Kenwood, Yamaha, Sony, and other classic stereo receivers
  • Versatile 12 volt AC or DC non-polarized operation
  • Flexible tinned 26 AWG 6" lead wires
  • Only 4mm in diameter
Your Price: $1.50
MSRP: $1.99
Save $0.49 (25%)
127 In Stock
We'll send you an email when 12V AC/DC Incandescent 4mm Grain of Wheat Panel Lamp with Insulated Leads is back in stock or available for preorder.
p>This 12 volt indicator lamp solders right in to the original bulb's location in Marantz, Sansui, Kenwood, Yamaha, Sony, and other classic stereo receivers. Manufacturers use incandescent lamps to back light tuner and panel displays in stereo amplifiers. You will fall in love with your stereo receiver all over again once you replace current burned out lights.
This lead lamp has multiple application possibilities, because it works with 12 volt AC or DC and it's tinned leads solder right into PC boards. Many cars use this lamp to light up dash instrument panels and car stereo displays. You will also find them backlighting LCD displays in portable and desk style communication radios. This tiny indicator lamp also works great in new 12V DIY project.
Specifications: • Dimensions: 0.45" H x 0.17" Dia. without the leads and at its widest point • Bulb diameter dimensions: 0.16" Dia. (4mm) • Lead length: 6" • Color: Warm white • Recommended voltage: 12 volts @ 60 mA • Working voltage: 3 to 14.4 volts.
Part Number070-107
UPC848864068275
Weight0.003
