Yung SD100-6 100W Class D Subwoofer Plate Amplifier Module with 6 dB at 45 Hz
Brand:|Model: SD100-6|Part # 301-502
Yung adds a 6 dB bass boost (centered at 45 Hz) to make the SD100-6 100W Class D subwoofer amplifier module a perfect fit for many custom designs or replacement duties.
List Price$149.99
You Save34%
$99.72
Part # 301-502
  • Class D amplifier circuit with switching power supply provides excellent efficiency
  • Capable of sustained, continuous output without thermal shutdown
  • Built-in limiter circuit protection prevents peak overloads
  • Low-level and LFE inputs for flexible interconnection
  • Manual and automatic on/off mode options
  • 6 dB @ 45 Hz bass boost plus fully adjustable phase, gain, and crossover points
  • Switchable 115/230V input voltage
Yung International's SD Series Class D subwoofer power amplifiers are equipped with the unique ability to operate continuously at full rated output—a performance attribute not shared by most home audio amp designs. The benefits of this remarkable reserve capacity include solid, punchy dynamic range and fewer "nuisance" shutdowns when operated at sustained high levels. A bass boost option enables the addition of 6dB of EQ centered at 45 Hz, perfect for sealed enclosures and even certain vented box alignments.
The amplifiers are also extremely compact, lightweight, and cool-running, allowing users to enjoy the advantages of compact system form factors and flexibility of placement. An internal peak limiting circuit prevents amplifier overload, and protection against internal and external faults is also provided. Input power requirements are user configurable to either 115 VAC or 230 VAC line voltage.
Room optimization and system integration are accomplished easily, thanks to the SD Series amps' inclusion of fully variable level, crossover frequency, and phase controls. Signal input is connected via dual RCA-type jacks, including the means to accept the output of an A/V receiver's LFE output, and dual RCA jacks are also provided to facilitate line level loop-through. When in standby mode, the amp's full active operation is engaged by signal presence of less than 1/2 watt.
Specifications: • Measured power output: 100 watts RMS into 4 ohms @ < 1.0% THD • Signal to noise ratio (at rated power): >90 dB • Input sensitivity (@ low level): 210 mV/50 Hz • Bass boost: 6 dB @ 45 Hz • Low pass adjustment: 40 Hz to 200 Hz • Phase adjustment: Continuously variable from 0º (normal) to 180º (reverse) • Power requirements: Switchable, 115/230 VAC, 50/60 Hz • Dimensions: 8" W x 7" H x 2-1/4" D; Cutout dimensions: 7-1/4" W x 6-1/4" H.
  • BrandYung International
  • ModelSD100-6
  • Part Number301-502
  • UPC844632095597
  • Product CategorySubwoofer Plate Amplifiers
    (3 Reviews)
  • Weight2.8 lbs.
View similar products to the Yung SD100-6 100W Class D Subwoofer Plate Amplifier Module with 6 dB at 45 Hz
in the Subwoofer Plate Amplifiers product category.
Yung SD100-6 100W Class D Subwoofer Plate Amplifier Module with 6 dB at 45 Hz is rated 4.3333 out of 5 by 3.
Rated 4 out of 5 by from Just one problem...This amp is a solid value and good performer. It never gets hot and the sound quality is nice. The biggest issue I have is that the 6db bass boost cannot be turned off. This made my setup more difficult and I will never be able to achieve the flat response I want. I don't mind bass boost, but it should be defeat-able.
Date published: 2013-02-18
Rated 5 out of 5 by from Great product...latest technologyI bought an Infinity Subwoofer at a garage sale for twenty bucks...the guy said it worked. Ha. The amp was shot. I was looking for something to replace it with and found the Yung SD100-6 had all the specs I needed. When it arrived, I was very surprised at the lack of huge, heavy power transformer. Class D amp with switching power supply takes up little space, runs cool and really packs a wallop. I had to make the hole in the cabinet a tiny bit bigger and it popped right in. Sounds awesome. Love it! Highly recommended.
Date published: 2012-09-24
Rated 4 out of 5 by from Good productSeems well designed and takes up less space than other products with similar specs.
Date published: 2012-07-05
  • 2016-05-05T06:10CST
  • bvseo_cps, prod_bvrr, vn_cps_3.2.0
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_301-502, PRD, sort_mostRecent
Hi I have a powered Dali AW10 sub woofer with a possible short on the pcb.Just a flashing red light at the back and no sound.Can you recommend a replacement plate amplifier module for it please. regards Craig
Asked by: craka
This question requires some additional measurements to provide an accurate answer.. Please contact our technical support department at 800-338-0531 or by email at tech@parts-express.com for help.
Answered by: Chrisf
Date published: 2016-04-14
i search a ampli plate for the size for polk audio psw125 dp you have something to fit in ?
Asked by: Sylvain lavigne
We do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Date published: 2015-11-09
I have a pair of 12" 8ohm subs,could i hook them to this amp
Asked by: snowman85
Yes, wiring the subs in parallel will yield a safe 4 ohm load for the amplifier.
Date published: 2015-09-25
I am interested with using this amp with a 8-Inch Woofer, power Handling: 25 to 150-Watts ; Impedance: 8 ohm. Will this amp handle it?
Asked by: orenb
Yes this amp will work fine for that application.
Date published: 2015-01-20
Can this work with KEF 2150 , if not can you suggest which will work?
Asked by: oolong
Date published: 2015-01-06
Can I use this amp to replace in a Energy ESW10
Asked by: Silverrain1732
Date published: 2014-10-30
  • 2016-05-05T06:47CST
  • bvseo_cps, prod_bvqa, vn_cps_3.2.0
  • co_hasquestionsanswers, tq_17
  • loc_en_US, sid_301-502, PRD, sort_recentQuestionsFirst
