XTC 6-1/2" Round Small Frame Shallow Foam Baffle Pair
Brand:|Model: VXT652|Part # 260-791
XTC VXT652 foam baffles protect 6-1/2" speakers from the dirt, water, and noise associated with mobile audio applications.
$7.78
Buy 10+$6.22
Part # 260-791
  • Protects speakers from water damage and corrosion
  • Improves audio performance of door and panel mounted speakers
  • Self-isolating and self-damping design minimizes door panel noise
  • Keeps contaminants away from speaker cone and voice coil gap
  • Use with full-range speakers, woofers, midbasses, midranges, and coaxial systems
  • Make your speakers live longer!
Don't let road dust, trips through the car wash, or precipitation ruin your expensive mobile audio system speakers! XTC VXT652 foam baffles protect your investment from harsh conditions, while at the same time guaranteeing peak acoustical performance.
An XTC VXT Series foam baffle protects easily corroded plated parts and vulnerable voice coil gaps. Creation of a separate chamber for the speaker's rear radiation also tightens bass response, reduces distortion, and minimizes the intrusion of road noise though the speaker's cone. The baffle's flexible, long lasting non-degrading composition does not absorb water.
The XTC foam baffle construction also creates an airtight seal for the speaker but also decouples it to prevent annoying speaker-to-panel resonances. Useful in car doors, rear decks, and other interior panels, as well as sub-enclosures for midrange drivers used in large home or PA speaker systems. For use with 6-1/2" speakers. 2-3/8" deep. Sold in pairs.
  • BrandVertek/XTC
  • ModelVXT652
  • Part Number260-791
  • UPC844632093135
  • Product CategoryWaterproof Foam Speaker Baffles
  • Unit of MeasurePR
    (4 Reviews)
  • Weight0.05 lbs.
XTC 4"x10" Oval Foam Baffle Pair
Part #  260-784
XTC 10" Round Foam Baffle Pair
Part #  260-794
View similar products to the XTC 6-1/2" Round Small Frame Shallow Foam Baffle Pair
in the Waterproof Foam Speaker Baffles product category.
XTC 6-1/2" Round Small Frame Shallow Foam Baffle Pair is rated 4.5 out of 5 by 4.
Rated 5 out of 5 by from worth the extra few bucks to protect your speakersEasy to install form fitting foam cups work well at tightening up bass response , blocking noise interference from door cavity , waterproofing your speakers, and protecting your aftermarket speakers.
Date published: 2015-09-22
Rated 5 out of 5 by from Well made, flexible and easy to work.Easily cut a slit to pull wire through and slipped it like a boot over the back of the woofer magnet.
Date published: 2015-04-14
Rated 5 out of 5 by from Smart addition for car door speakers.Good idea to protect new speakers in doors and get best sound from them.
Date published: 2015-02-07
Rated 3 out of 5 by from Will Greatly Affect QtcThis baffle is made of cheap foam, and measures only .7 liters. Im not sure if the foam will expand while the woofer is playing, but it looks like it would balloon up. You will probably have to choose a specific woofer for these baffles. Look for low qts and vas
Date published: 2011-10-15
  • 2016-02-09T06:29CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_260-791, PRD, sort_mostRecent
Will this baffle fit the PRV 6MB200 8 Ohms speaker in a Chrysler 300 2012 door?
Asked by: Bishop
It looks like that vehicle uses 6"x9" speakers in the doors so an adapter plate will need to be used. Otherwise this combination should work fine in that vehicle.
Date published: 2015-06-22
  • 2016-02-09T07:01CST
  • loc_en_US, sid_260-791, PRD, sort_recentQuestionsFirst
