Xantech RGC11 Remote Gain Control Module
Brand:|Model: RGC11|Part # 182-468
The remote gain control module allows line level control of audio power amplifiers where remote control is desired. Gain control is accomplished by infrared commands from a Xantech RC68+ (or RC68) Programmer.
List Price$200.00
You Save33%
$133.33
Part # 182-468
  • Remote controlled line level gain control
  • Ramping volume and/or preset level adjustments
  • Separate mute on and off
  • Selectable IR code groups
  • Useful for controlling multiple power amplifiers from a single preamp
The remote gain control module allows line level control of audio power amplifiers where remote control is desired. Gain control is accomplished by infrared commands from a Xantech RC68+ (or RC68) Programmer. This control module features selectable IR code groups that can be set to different group codes, allowing different IR code combinations. This prevents interaction in common IR systems when more than one gain control module is being used, or if modules are included with other Xantech products using RC68+ codes.
Specifications: • Responds to 16 IR commands: Volume up/down ramping, 12 Fixed Levels, Mute ON and Mute OFF • IR Confirm LED lights • Gold plated RCA type input & output jacks • Loop-through jacks (not buffered) for "daisy chaining" • Factory preset Group Code number: 30 • 4-terminal plug-in for IR input & power connections, IR IN (= IR Signal), G (= GND), V (= 15VAC). Accepts wire sizes from 24 to 12 gauge • Input impedance: 45 k Ohms • Output impedance: 220 Ohms • S/N Ratio: >103 dB "A" WTD re 2V out • Gain: Unity @ Max. V.C. • Frequency response: 5 Hz to 70 kHz ± 3 dB • THD: <0.01% @ 2V out, IEC 'A' weighted • Requires RC68+ Programmer IR codes for operation • Power requirements: 15VAC @ 85 mA. (15V AC power supply included) • Dimensions: 5-7/8" x 2-3/4" x 1-5/8".
  • BrandXantech
  • ModelRGC11
  • Part Number182-468
  • UPC042777300419
  • Product CategoryIR Software / Keypad Modules
  • Weight1 lbs.
View similar products to the Xantech RGC11 Remote Gain Control Module
in the IR Software / Keypad Modules product category.
