Xantech ML85 LCD/CFL Micro Link IR Receiver
Brand:|Model: ML85|Part # 182-656
The Micro Link IR Receiver is equipped with a 7 ft. cable and a 3.5 mm stereo mini plug, which is plugged directly into the "IR RCVR" jack on the connecting block
Part # 182-656
  • Small size; mounts in 1/2" diameter hole. 2" deep
  • Quick-Connect 3.5 mm stereo mini plug on 7 ft. cable for direct plug-in to Xantech connecting Block
  • Works in normal 3-wire mode (12VDC, IR, GND)
  • Green Talkback LED for system verification
The Micro Link IR Receiver is a small peep-hole style infrared repeater assembly. The Micro Link IR Receiver is equipped with a 7 ft. cable and a 3.5 mm stereo mini plug, which is plugged directly into the “IR RCVR” jack on the connecting block, such as the models 789-44, CB60, and 791- 44. The Micro Link IR Receiver is primarily intended for use in installations where the connecting block is within reach of its 7 ft. cable – as when installing the Micro Link IR Receiver in a cabinet where the controlled equipment is behind closed doors.
Features and Specifications: • Infrared modulation frequency bandwidth: 30 – 60 kHz • IR reception range: Up to 80 ft. • Reception angle: 55 degrees off axis for 50% range reduction • Maximum transmission length: 1 mile using 18 gauge wire • Maximum current output: 100mA • Drives IR emitters through Xantech connecting blocks, controllers, etc. • Dimensions: 1/2" diameter x 2" deep • Power requirements: +12VDC, 20mA.
  • Mounting StyleTube Style
  • BrandXantech
  • ModelML85
  • Part Number182-656
  • UPC042777318384
  • Product CategoryIR Targets
  • Weight0.3 lbs.
View similar products to the Xantech ML85 LCD/CFL Micro Link IR Receiver
in the IR Targets product category.
