Xantech CB20 One Zone Connecting Block
Brand:|Model: CB20|Part # 182-472
The Model CB20 provides a low cost means of connecting Xantech "Quick Connect" IR Receivers to 2 single or 2 dual emitters and a power supply in an infrared repeater system.
Comparable Items In Stock:
Part # 182-472
The Model CB20 provides a low cost means of connecting Xantech "Quick Connect" IR Receivers to 2 single or 2 dual emitters and a power supply in an infrared repeater system. CAUTION: Plug only Xantech IR Receivers equipped with a stereo mini plug into the IR jack. Do not plug emitters or other devices into this jack; to do so will destroy emitters and damage power supplies.
Specifications: • Inputs: 1 - IR Receiver "IR" 3.5mm stereo mini jack • Accepts any Xantech IR Receiver equipped with a 3.5mm stereo mini plug, such as the 291-00 and 490-30 • Outputs: 2 - Emitter "OUT" ports (3.5mm mono mini jacks) parallel driven • Contains a 470-Ohm resistor in series with each OUT jack • Model 282, 283, 284 & 286 Xantech Mini Emitters may be used • Power requirements: 12 volts DC. Uses 781RG Power Supply • 2.1mm coaxial power jack • Dimensions: 2-1/8" x 1-1/4" x 3/4".
  • BrandXantech
  • ModelCB20
  • Part Number182-472
  • UPC042777300082
  • Product CategoryIR Connecting Blocks
    (2 Reviews)
  • Weight1 lbs.
View similar products to the Xantech CB20 One Zone Connecting Block
in the IR Connecting Blocks product category.
