Xantech 791-44 One Zone Amplified Connecting Block
Brand:|Model: 791-44|Part # 182-484
The Model 791-44 is an amplified connecting block that can handle up to 10 single or 10 dual emitters (or any combination) to be driven at high or low power levels. Up to 100 emitter ports may be driven using 790-00 passive connecting blocks 'daisy chained' from the HIGH IR OUT port.
List Price$102.00
You Save39%
$62.63
Part # 182-484
  • Emitter ports with jumpers permit high or low power
  • High-speed opto-isolator for improved operation
  • Parallel emitter ports drive 10 single or 10 dual emitters
  • Up to nine 790-00's can be connected if more than 10 emitter ports are needed
The Model 791-44 is an amplified connecting block that can handle up to 10 single or 10 dual emitters (or any combination) to be driven at high or low power levels. Up to 100 emitter ports may be driven using 790-00 passive connecting blocks 'daisy chained' from the HIGH IR OUT port. The 791-44 can interface with all Xantech IR Receivers and Keypads to the emitters along with a power supply. It can also serve to provide emitter expansion at the output port of other Xantech devices, such as the 590 Programmable Controller, the 710 Fone Link™ and the 796 Zone Expander. A floating terminal is provided for "STATUS" line connections.
Specifications: • 4-screw plug-in terminal for +12VDC, GND, STATUS, & IR IN • Quick connect "IR RCVR" input (3.5mm mini stereo jack) • Red talk-back LED flashes with IR input signal • Ten EMITTER output ports, parallel driven (3.5 mm mini mono jacks) • HIGH IR OUT port for emitter expansion (3.5 mm mini mono jack) • Use of included jumpers connect either a 100 or a 470-Ohm resistor in series with each emitter jack for high or low power operation • 282/283/284/286 series of Emitters may be used in any combination • Power requirements: 12 volts DC. Use 781RG or 782-00 power supplies • 2.1 mm coaxial power jack • Dimensions: 6" W x 2-1/4" D x 15/16" H.
  • BrandXantech
  • Model791-44
  • Part Number182-484
  • UPC042777791446
  • Product CategoryIR Connecting Blocks
    (5 Reviews)
  • Weight0.62 lbs.
View similar products to the Xantech 791-44 One Zone Amplified Connecting Block
in the IR Connecting Blocks product category.
Xantech 791-44 One Zone Amplified Connecting Block is rated 4.6 out of 5 by 5.
Rated 4 out of 5 by from Works well, good for tricky setupsI replaced a simpler passive 10 way block with this unit and it works much better. The 2 output levels selectable per output is great. I'm happy with it.
Date published: 2009-05-27
Rated 5 out of 5 by from Works as advertisedExpanded my Pronto Professional's IR control capability by outputting IR from a RFX9600 port to this product, giving me 10 more IR outputs. Works well.
Date published: 2009-01-22
Rated 4 out of 5 by from Good experienceI had no problem from Parts Express when ordering this product. It was recommended to me by a Xantech technical representative. After testing it, however, the connecting block that came with the kit worked fine, which says more about Xantech rather than Parts Express. Good experience with Parts Express and will use them again in the future.
Date published: 2008-06-17
Rated 5 out of 5 by from great price, fast shipping, woohoo!Great IR connecting block. give lots of flexibility for expansion, power selection for emitters, and well made. thumbs up from me...
Date published: 2008-03-18
Rated 5 out of 5 by from Xantech, The Bast Name in IRI've been using Xantech products for years, no others compare
Date published: 2008-01-24
  • 2016-02-10T06:53CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_182-484, PRD, sort_mostRecent
Can I use a class 2 power supply AC/DC adapter:  input 100-240V-50/60Hz 0.5A  Output 12V --- 1.2A  with this Xantech 791-44  1-Zoe Amplified Coeig Bok?
Asked by: Rifleman
Yes that will work fine as long as it has a 2.1mm x 5.5mm plug.
Date published: 2015-02-12
  • 2016-02-10T07:47CST
  • loc_en_US, sid_182-484, PRD, sort_recentQuestionsFirst
