Xantech 789-44D One Zone In-Wall Connecting Block
Brand:|Model: 789-44D|Part # 182-480
The Model 789-44D is a single gang, in-wall version of the 789-44 Connecting Block and is trimmed with a standard Decora style cover plate (not included). Allows the connection of Xantech IR Receivers and Keypads to four emitters, with a power supply, in infrared repeater systems.
Comparable Items In Stock:
Part # 182-480
  • Similar to the standard 789-44 but used in a J-box configuration
  • Can be used at either end of an infrared buss system
  • Four parallel emitter ports on external connecting plate
  • Quick connect stereo mini jack for Xantech IR receivers
  • 4-terminal plug in connector on the back of the plate for Power and IR Signal
The Model 789-44D is a single gang, in-wall version of the 789-44 Connecting Block and is trimmed with a standard Decora style cover plate (not included). Allows the connection of Xantech IR Receivers and Keypads to four single or four dual emitters, with a power supply, in infrared repeater systems. It can also provide emitter expansion for various Xantech devices, such as the 590, 710, 796-20, and others. The STATUS terminal provides a convenient connecting point for voltage to drive STATUS indicators on certain Xantech products, such as the 780-80 IR Receiver.
Specifications: • Inputs: 1 - Screw-type, 4-terminal plug-in. 1 - IR RCVR, 3.5 mm stereo mini jack • Outputs: 4 - Emitter ports (3.5 mm mono mini jacks) parallel driven • Contains a 470-Ohm resistor in series with each emitter output • Xantech 282, 283, 284 & 286 series Emitters may be used • Power: 12 volts DC, 2.1 mm coaxial power jack • Use a 781C-00 or 782-00 Power Supply • Note: Don NOT connect a power supply to the 789-44D when it is used as an emitter expander only • Dimensions: 1-3/8" W x 1-3/4" D x 4-1/8" H.
  • BrandXantech
  • Model789-44D
  • Part Number182-480
  • UPC042777311071
  • Product CategoryIR Targets & Connecting Blocks
  • Weight1 lbs.
View similar products to the Xantech 789-44D One Zone In-Wall Connecting Block
in the IR Connecting Blocks product category.
