Xantech 789-44 One Zone Connecting Block
Brand:|Model: 78944|Part # 182-476
The 789-44 provides a quick, low cost way of connecting Xantech IR receivers and keypads to four single or four dual emitters, with a power supply, to create an infrared repeater system.
- Order Soon - Only 3 Left In StockMore Due In October 5, 2016
List Price$62.00
You Save40%
$37.46
Part # 182-476
  • Connects four emitter ports and power supply to all Xantech infrared receivers and keypads
  • Four parallel emitter ports with 470 Ohm resistors drive 4 single or 4 dual emitters
  • Quick-connect stereo mini jack
  • STATUS terminal for connection of Xantech IR Receivers and Keypads that have status indicator LED's
The 789-44 provides a quick, low cost way of connecting Xantech IR receivers and keypads to four single or four dual emitters, with a power supply, to create an infrared repeater system. It can also provide emitter expansion for various Xantech devices, such as the 792-10, 795-20, 796-20, and others. The STATUS terminal provides a convenient tie point for voltage to drive the STATUS indicator on certain Xantech products, such as the 780-80 IR Receiver.
Specifications: • Inputs: 1 - Screw type 4-terminal plug-in. 1 - IR Receiver "IR RCVR" 3.5 mm stereo mini jack • Outputs: 4 - Emitter ports (3.5 mm mono mini jacks) parallel driven • Contains a 470 Ohm resistor in series with each emitter output • Xantech 282, 283, 284 & 286 Mini Emitters may be used • Power requirements: 12 volts DC. Uses 781RG or 782-00 Power Supplies • Note: Do NOT use a power supply to the 789-44 when it is used as an emitter expander • 2.1 mm coaxial power jack • Dimensions: 2-15/16" W x 1-3/4" D x 13/16" H.
  • BrandXantech
  • Model78944
  • Part Number182-476
  • UPC042777789443
  • Product CategoryIR Connecting Blocks
    (1 Reviews)
  • Weight1 lbs.
View similar products to the Xantech 789-44 One Zone Connecting Block
in the IR Connecting Blocks product category.
