Xantech 283TPD Designer Visible/Blinking IR Emitter Twn Plug
Brand:|Model: 283TPD|Part # 182-678
The 283TPD Blink-IR Designer Emitter contains a small infrared LED housed in a miniature, diamond shaped plastic shell. Configured with two 3.5 mm mono plugs allows control of single source by two IR systems.
ORDER TODAY
Ships in 7-10 Business Days
List Price$21.00
You Save39%
$12.89
Part # 182-678
  • Visible, low-output version of the 282M
  • Deep purple Lexan® shell
  • Clear adhesive film
  • Lead is terminated with a 3.5 mm mono mini plug
  • Length of wire: 10 ft.
Frequently Bought Together
The 283TPD Blink-IR Designer Emitter contains a small infrared LED housed in a miniature, diamond shaped plastic shell. Unlike other emitters, the 283M emits visible red light in addition to IR (infrared) control signals when activated by IR receivers or other Xantech controllers. Configured with two 3.5 mm mono plugs allows control of single source by two IR systems. The Designer Emitter is designed to be installed directly on the IR control window of the equipment. The almost black (deep purple) shell passes infrared (IR) leaving access to the original remote controller while at the same time making the most unobtrusive installation possible. The designer emitters are made of a deep purple Lexan® for improved infrared pass-through, allowing a greater range of direct control of components from hand-held controllers.
  • BrandXantech
  • Model283TPD
  • Part Number182-678
  • UPC042777315529
  • Product CategoryIR Emitters
  • Weight0.16 lbs.
View similar products to the Xantech 283TPD Designer Visible/Blinking IR Emitter Twn Plug
in the IR Emitters product category.
