Xantech 283D Blink-IR Designer Emitter
Brand:|Model: 283D|Part # 182-492
The 283M Blink-IR Designer Emitter contains a small infrared LED housed in a miniature, diamond shaped plastic shell. Unlike other emitters, the 283M emits visible red light in addition to IR (infrared) control signals when activated by IR receivers or other Xantech controllers.
List Price$22.00
You Save41%
$12.89
Part # 182-492
The 283M Blink-IR Designer Emitter contains a small infrared LED housed in a miniature, diamond shaped plastic shell. Unlike other emitters, the 283M emits visible red light in addition to IR (infrared) control signals when activated by IR receivers or other Xantech controllers. The Designer Emitter is designed to be installed directly on the IR control window of the equipment. The almost black (deep purple) shell passes infrared (IR) leaving access to the original remote controller while at the same time making the most unobtrusive installation possible. The designer emitters are made of a deep purple Lexan® for improved infrared pass-through, allowing a greater range of direct control of components from hand-held controllers.
Specifications: • Visible, low-output version of the 282M • Deep purple Lexan® shell • Clear adhesive film • Two 1/2" pieces of double-sided clear adhesive tape • Lead is terminated with a 3.5 mm mono mini plug • Length of wire: 10 feet.
  • BrandXantech
  • Model283D
  • Part Number182-492
  • UPC042777315482
  • Product CategoryIR Emitters
    (8 Reviews)
  • Weight0.08 lbs.
View similar products to the Xantech 283D Blink-IR Designer Emitter
in the IR Emitters product category.
