CLEARANCE
Xantech 282TPD Designer IR Emitter Twin Plug
Brand:|Model: 282TPD|Part # 182-674
The 282TPD Designer Emitter contains a tiny infrared LED housed in a miniature, diamond shaped plastic shell. Configured with two 3.5 mm mono plugs allows control of single source by two IR systems.
- Order Soon - Only 3 Left In Stock
List Price$22.00
You Save33%
$14.70
Part # 182-674
  • Non visible, high output version
  • New deep purple Lexan® shell
  • Clear adhesive film
  • Lead is terminated with a 3.5 mm mono mini plug
  • Length of wire: 10 ft.
The 282TPD Designer Emitter contains a tiny infrared LED housed in a miniature, diamond shaped plastic shell. It emits IR (infrared) control signals sent to it by IR receivers or other Xantech controllers. Configured with two 3.5 mm mono plugs allows control of single source by two IR systems. The 282TPD can be installed directly on the IR sensor window of the controlled device or other suitable location. The Designer Emitter is designed to be installed directly on the IR control window of the equipment. The almost black (deep purple) shell passes infrared (IR) leaving access to the original remote controller while at the same time making the most unobtrusive installation possible. The designer emitters are made of a deep purple Lexan® for improved infrared pass-through, allowing a greater range of direct control of components from hand-held controllers.
  • BrandXantech
  • Model282TPD
  • Part Number182-674
  • UPC042777315611
  • Product CategoryIR Emitters
  • Weight0.23 lbs.
View similar products to the Xantech 282TPD Designer IR Emitter Twin Plug
in the IR Emitters product category.
