X-Treem Articulating TV Wall Mount with Tilt 23"-46" Black
Brand:|Part # 182-030
X-Treem Mounts are ideal for extreme applications. Capable of holding LCD or Plasma televisions from 23"-46" and weighing up to 110 pounds this mount won't let you down.
A restocked/refurbished, or Open Box unit of this product is available -- see it now
List Price$189.99
You Save33%
Buy 4-19 $114.94
Buy 20+$105.36
Part # 182-030
  • Fits flat screen televisions from 23" ~ 46"
  • Supports televisions weighing up to 110 lbs.
  • VESA 100 x 100 / 200 X 200
  • Adapter plate available for larger TVs with VESA 300 x 300 or 400 x 400 patttern
  • Extends 19" from wall to accomodate many viewing angles
  • Rotates 180° monitor, 360° at mid-section and 180° at wall
  • Quik-Fix mounting system
X-Treem Mounts are manufactured from 1-1/2" OD aluminum tube and powder coated for a lifetime of use. Compatible with VESA standard 100x100 / 200x200 mount monitors. This articulating X-Treem mount rotates 180° at the monitor, 360° at the mid-section and 180° at the wall allowing you to extend the monitor out 19" or store virtually flat against the wall. Tilt the monitor +/- 12° to get the perfect viewing angle. The Quik-Fix mounting bracket system makes installation much easier than other mounts. Simply mount the wall plate and set the monitor arm into the wall plate positive receptacles and finish the installation with two set screws.
Specifications: • Wall Bracket: 3" W x 15.5" H • TV Bracket: 8.5" W x 8.5" H • Tilt Adjustment: +/- 12° • Supports VESA sizes: 200 x 200 • Maximum Weight Capacity: 110 lbs.
NOTE: Consult your TV's owners manual for VESA sizing information. For VESA sizes 300 x 300 and 400 x 400 use adapter plate #182-031.
  • Mount TypeFull-Motion Articulating
  • Mount StyleWall Mount
  • TV Capacity20" to 29",30" to 39",40" to 49"
  • BrandParts Express
  • Part Number182-030
  • UPC844632077531
  • Product CategoryTV Mounts & Brackets
    (11 Reviews)
  • Weight17.4 lbs.
View similar products to the X-Treem Articulating TV Wall Mount with Tilt 23"-46" Black
in the TV Mounts & Brackets product category.
