X-Over 3 Pro Software CD-ROM
Brand:|Model: X-Over 3 Pro|Part # 500-919
X-over Pro Version 3.0 combines a passive filter design with a powerful circuit modeler. In addition to designing a passive crossover network or filter, it also predicts its response and shows what happens when one or more components are changed.
List Price$129.00
You Save23%
$99.00
Part # 500-919
X-over Pro Version 3.0 combines a passive filter design with a powerful circuit modeler. In addition to designing a passive crossover network or filter, it also predicts its response and shows what happens when one or more components are changed. Display and print schematics, component parts lists and graphs. Using the same style user interface as BassBox Pro, it is very quick and easy to use. (Get X-Over 3 Pro and Bass-Box 6 Pro all in one package buy: BASSBOX 6 PRO/X-OVER 3 PRO SOFTWARE SET CD-ROM).
  • BrandHarris Technologies
  • ModelX-Over 3 Pro
  • Part Number500-919
  • UPC844632060687
  • Product CategorySpeaker & Crossover Design Software
    (10 Reviews)
  • Weight1.2 lbs.
View similar products to the X-Over 3 Pro Software CD-ROM
in the Speaker & Crossover Design Software product category.
X-Over 3 Pro Software CD-ROM is rated 4.0 out of 5 by 10.
Rated 1 out of 5 by from Won't install, a decade behind Windows 7I purchased this with the fear that the software was a little behind, and I was right. On my Windows 7/64 bit rig it will simply not install. On a clean VM that I rented from Amazon just for this purpose it would not load the speaker driver files. One major issue is that for some dorkus reason it scans your entire hard drive for previous copies. Talk about bad design! WHO DOES THIS? In my normal PC with about 2TB of disks, 70% used up with games and Autodesk programs and music this process takes about an hour and a half before I get an installer error message. Spoke to them, the delay in installation is apparently known, but apparently for most it eventually does finish.
Date published: 2015-09-16
Rated 5 out of 5 by from Best Yet!I've used the first version years ago that came on a floppy. Having the need to check the design of my professional crossovers I opted to purchase this newer version. It is a very good design tool. The one thing I really like is that it provides an option for standard capacitors and chokes instead of having to series/parallel several to get your values. Plus you can go simple design or elaborate where you enter all the Theile Small parameters. I'm very pleased with it
Date published: 2015-02-16
Rated 5 out of 5 by from Value of this productThis product helped me to scrap most of my project. I wish I had bought this first. The software not only models the crossover network but integrates the speaker data (TS parameters and test data) to provide an extremely helpful view of the output of the project before spending money on components. When I got to the testing phase of my build, something just didn't sound right. I had chosen components that were good but a bad match for my objectives. Buying this first would have saved me hundreds of dollars.
Date published: 2014-09-04
Rated 5 out of 5 by from I like itIt's a good piece of software and I am glad to have purchased it. I did expect a little more from it though. Before buying this I would read Loudspeaker Design Cookbook. A very informative book. I am still playing with it and I do like how easy it is to use. This is a great tool to have with other sources of information about designing crossovers. Overall, I would recommend it, especially if you are someone like me who is new to crossover designs.
Date published: 2014-06-28
Rated 4 out of 5 by from Good Mid-Level XO Designer SoftwareThis is a really good mid-level crossover design package. It goes well beyond the "textbook" level, but does not quite approach the level of some of the software available (Jeff B.'s free software in particular). However, it is very easy to use once you have gained an good solid foundation in XO design. Note -- Users need to have a good foundation, such as that gained from reading David Weems' and especially Ray Alden's books.
Date published: 2009-09-24
Rated 4 out of 5 by from Will save your timeWill save your time and mind :) Must to have for any serious speaker builder. Easy to use, fine results if all speaker data entered...
Date published: 2008-05-18
  • 2016-02-07T06:19CST
  • co_hasreviews, tv_0, tr_10
  • loc_en_US, sid_500-919, PRD, sort_mostRecent
I have windows 10 , does this software  work with  it ?
Asked by: Randyc57
Yes this will work with Windows 10.
Date published: 2015-11-02
Does this software take the impedance rise of woofers into consideration? Does it account for impedance peaks at resonance of tweeters? Can you input the actual frequency response of the speaker? Or does it consider all drivers ideal? Thanks.
Asked by: Joe3
You can enter in all THIELE-SMALL parameters including frequency response. Design aspects are based on speaker actual parameters.
Answered by: TomI
Date published: 2015-01-21
Does this have a crossover optimizer, meaning does it adjust the value of the crossover components to get a flat response?
Asked by: DaveSpectral
Unfortunately it does not, however you are able to change individual component values to make the modeled response as flat as you would like.
Date published: 2014-03-24
Does this support a dual-woofer design?
How does this software support use of a dual-woofer in a 3-way design or MTM? Can I enter the drivers directly or do I need to do something special to implement this?
Asked by: WavingPine
Yes this allows you to use essentially how ever many drivers you would like for woofer, mid or tweeters, as long as they are identical. You simply change the quantity and load the driver wiring configuration you want.
Date published: 2013-11-04
Will this work for Windows 8?
Asked by: mr. music
Yes this does work with Windows 8.
Date published: 2013-08-13
Doex X-over pro 3 contain horn drivers in thier database?
Asked by: TCoff
Unfortunately no, there are too many horn lens options available to have any kind of accuracy with a model.
Date published: 2015-02-01
  • 2016-02-07T07:15CST
  • co_hasquestionsanswers, tq_8
  • loc_en_US, sid_500-919, PRD, sort_recentQuestionsFirst
