300-616_ALT_0
300-616_ALT_1
300-616_ALT_2
Wired Home WPI-5.1 5.1 Channel Home Theater Speaker Wall Plate
Brand:|Model: WPI-5.1|Part # 300-616
The WPI-5.1 is the ideal accessory to finish off your home theater. This simple to use wall plate allows for all speaker wires to be run within the walls for a clean professional look.
List Price$39.99
You Save33%
$26.96
Buy 4+$25.27
Part # 300-616
  • High quality, low cost
  • Simplifies installation
  • Unique dual-subwoofer RCA input
  • Gold-plated binding post
  • Clean look and finish
The WPI-5.1 is the ideal accessory to finish off your home theater. This simple to use wall plate allows for all speaker wires to be run within the walls for a clean professional look. The contemporary Decora® style features gold plated binding posts for each speaker and offers unique dual RCA jacks for multiple subwoofers. The inserts are labeled for each speaker location and correlate to most home audio receivers. Fits in a standard 2 gang electrical box. Kit includes: Decora® wall plate, 2 labeled Decora® inserts, 10 gold plated binding posts (5 red/5 black), 2 gold plated RCA jacks and all mounting hardware.
  • BrandWired Home
  • ModelWPI-5.1
  • Part Number300-616
  • UPC844632007309
  • Product CategoryHome Theater Pre-Configured Wall Plates
    (23 Reviews)
  • Weight0.5601 lbs.
View similar products to the Wired Home WPI-5.1 5.1 Channel Home Theater Speaker Wall Plate
in the Home Theater Pre-Configured Wall Plates product category.
Wired Home WPI-5.1 5.1 Channel Home Theater Speaker Wall Plate is rated 4.3478 out of 5 by 23.
Rated 4 out of 5 by from Looks great works wellThere are several of these floating around the internet. These are on par or slightly better quality than many of the others. The posts are similar all around. They are decent. Banana posts fit snug, which is good. The plating is necessary, it will delay the corrosion and provide good signal for a while.I would recommend these to any with a 5.1{2} system.Enjoy the Show
Date published: 2013-01-14
Rated 5 out of 5 by from AWSOME SPEAKERSAWESOME SPEAKER WALL PLATES. GREAT QUALITY. VERY WELL MADE. MADE IN THE USA. CLEARLY MARKED SPEAKER WALL PLATES. THESE WALL PLATES REALLY GIVE YOUR SURROUND SOUND SPEAKER SYSTEM INSTALLATION A REAL PROFESSIONAL LOOK. I HIGHLY RECOMMEND THESE SPEAKER PLATES TO ANYONE LOOKING FOR THAT PROFESSIONAL SPEAKER SYSTEM INSTALLATION. THE ONLY CON I HAVE ABOUT THEM IS THAT THEY ARE EXPENSIVE.
Date published: 2012-11-26
Rated 4 out of 5 by from Looks good!Really easy, straight forward and looks nice although, I had to get different screws for mounting the insert to the gang box. The screws that came with the kit stripped like play-dough. It could have been a bad couple of screws but other than that, I like it.
Date published: 2012-09-28
Rated 4 out of 5 by from Makes for a really nice installThese really make your home theatre look great. Makes it a real breeze to hook up new equipment as well. My only complaint was that I had to order 2 binding posts to replace the RCA connections for the subwoofer. I do not have a plate amp on my subwoofer life most do. Just had to purchase and install 2 binding posts from an extra wall plate.
Date published: 2009-12-14
Rated 4 out of 5 by from Professional finishI gave a 4 on value as I was a little surprised at the cost. No wonder it took me 12 years to finish this part of my home theater! But the result is well worth it. It looks great! It was easy to install and even a novice like myself was able to make it look good. Recommended.
Date published: 2009-07-16
Rated 3 out of 5 by from Good functional performance, minor flawsPlates look really clean and connectors work well. However, did not fit as well as I would have liked with standard Decor wall plates. The mounting screws aren't recessed enough from the actual plate, so when wall mounted the plate is somewhat recessed from the surrounding cover plate.
Date published: 2009-03-16
  • 2016-02-07T06:40CST
  • co_hasreviews, tv_0, tr_23
  • loc_en_US, sid_300-616, PRD, sort_mostRecent
