182-850_ALT_0
182-850_ALT_1
182-850_ALT_2
182-850_ALT_3
Wired Home WHIRK2 Basic Tube Target IR Repeater Kit
Brand:| Model: WHIRK2
Product Video
This Wired Home IR kit includes all of the components you need to relocate four A/V components' IR targets (wire not included). Includes one IR hub with power supply, one 1/2" IR tube target, and four emitters.
  • Includes one target, an IR hub with power supply, and four emitters
  • Control up to four A/V components from another room
  • Future-proof expandability built-in, add up to 14 additional targets
182-850
Weight: 1.3 lbs.
IN STOCK
List Price$129.99
You Save23%
$99.78
Buy 4-up$94.04
Part # 182-850
This Wired Home IR kit includes all of the components you need to relocate four A/V components' IR targets (wire not included). Featured within the kit is Wired Home's WH-IR3500 1/2" diameter tube target that nearly disappears from sight, for use near a flat panel HDTV or on the outside of a component cabinet. The Wired Home WH-IRH IR hub and WH-PS power supply are included, and allow for future system expansion with power and signal routing for up to 14 additional targets. Four WH-1IRME emitters with self-adhesive and 10 ft. of cord round out the package.
  • BrandWired Home
  • ModelWHIRK2
  • Part Number182-850
  • UPC844632069352
  • Product CategoryIR Repeater Systems
    (19 Reviews)
  • Weight1.3 lbs.
View similar products to the Wired Home WHIRK2 Basic Tube Target IR Repeater Kit
in the IR Repeater Systems product category.
Wired Home WHIRK2 Basic Tube Target IR Repeater Kit is rated 4.3158 out of 5 by 19.
Rated 4 out of 5 by from Works as promised.I have now bought 3 of these units. It was a bit confusing hooking this unit up for the first time. There are 3 wires, and 4 spaces and the instructions were not very clear. I had to use google in order to find the right spots to connect. It was much easier the 2nd and 3rd time for obvious reasons. My only other complaint, is that when you start your system, sometimes there is a lag for the first minute or so. (This is very random, and only happens once in a while.) Other than that, this is a great kit and works as promised. I have now hidden all my equipment in closets and it has freed up a ton of floor space. I would definitely recommend this product if you are looking for an IR repeater. Add a universal remote and you will be golden.
Date published: 2014-01-23
Rated 5 out of 5 by from Nice solutionHave this for my cable reciever, blu ray, and denon receiver that are hidden... works perfectly!
Date published: 2012-05-02
Rated 5 out of 5 by from PerfectPerfect parts and functionality. Does exactly what it's supposed to. Controlling my Apple TV and my DVD player through the wall. So cool. I love this setup. I drilled through about 6 inches below the bottom edge of my wall-mounted plasma using a drill bit long enough to drill though the other side. Then I slid the wire through and secured the components and wires. Easy-pleasey, lemon-squeezy. No interference from Plasma, works flawlessly. Also shipped fast - excellent company to purchase from.- PE customer for life.
Date published: 2012-01-26
Rated 4 out of 5 by from Works great! w/ exception of motorola hd/dvrThis is a great product for the price.Although it works with my blu ray(samsung) and my reciever(denon) I cant get it to work with my motorola hd/dvr. I am trying several different models from my cable company,(2 so far) and it still doesnt work. If anyone knows of any answers for me help would be appreciated.
Date published: 2011-02-17
Rated 1 out of 5 by from Terrible Product - Bad CompanyThe perfect combo - terrible and incomplete instructions and a product that doesn't work properly for MANY common applications. First you have to set it all up (run wires through walls, snake emitters all through your system) only to have it not work. Then to troubleshoot...terrible instructions, so you think maybe you interpreted something wrong. Look on website - nothing helpful. Trial and error through all hookup permutations. Must be defective. Fun returning stuff that's already in your drywall. Clueless and unavailable support for this product. How do you include bad instructions for such a simple product? Only answer: institutionally dysfunctional organization - top-down.
Date published: 2013-05-09
Rated 5 out of 5 by from Helpful HintVery poor instructions! Here's what to do - the outside wire goes to ground, the center goes to voltage and the white goes to the IR.
Date published: 2011-05-12
duodvr vip 722k from dishnetwork
Wondering if this product would work with this model reciever.
Asked by: bmd81
Our IR repeater kits are designed to work with virtually any system that uses an infrared remote control. You may wish to call your satellite provider to verify that your system does, indeed, operate with an infrared remote. If that is the case, then this kit should be suitable for your application.
Answered by: RussR
Date published: 2011-07-29
Videos
Customer projects that include: Wired Home WHIRK2 Basic Tube Target IR Repeater Kit
