182-836_ALT_0
Wired Home WHIRE-KJ 3.5mm 2-Conductor / Mono Keystone Jack
Brand:| Model: WHIRE-KJ
The WH-IRE-KJ is an 3.5 mm jack that fits into any standard keystone wall plate. It's perfect for use with IR emitters!
  • Allows for clean installation of emitters in a distributed IR environment
  • Fits standard keystone wallplates for maximum compatibility
  • Quick and easy to install
182-836
Weight: 0.04 lbs.
IN STOCK
List Price$4.99
You Save29%
$3.51
Buy 12-up$3.34
Part # 182-836
The Wired Home 3.5 mm mono keystone jack fits into any standard keystone wall plate and provides easy no-soldering termination. In an IR repeater system, it provides a convenient point to connect an IR emitter. For home automation systems, this jack can be used to connect a serial cable. Features include spring terminals and a mini jack for simple installation. Standard Cat 5/5e wire can be used for transmitting IR or audio signals. Accepts up to 22 AWG. solid wire.
  • BrandWired Home
  • ModelWHIRE-KJ
  • Part Number182-836
  • UPC844632003059
  • Product CategoryIR Connecting Blocks
    (2 Reviews)
  • Weight0.04 lbs.
View similar products to the Wired Home WHIRE-KJ 3.5mm 2-Conductor / Mono Keystone Jack
in the IR Connecting Blocks product category.
Wired Home WHIRE-KJ 3.5mm 2-Conductor / Mono Keystone Jack is rated 3.5 out of 5 by 2.
Rated 3 out of 5 by from No IR; Only two wireThere is no documentation with the item or available at the web site. I found that, while the jack is a three wire TRS capable jack with insertion interrupt switches, the jack is soldered into a circuit board in such a way as to permit only a two wire TS configuration.There is no sign of an IR emitter in either the jack (which has a clear cover) or in the only other parts, the wire connectors. Those two wire connectors have what appears to be push to clamp wire closures but pushing on the apparent clamping mechanism only breaks apart the wire clamp. Instead, it is a catching mechanism similar to the back wire on newer outlets. It is suitable only for solid wire and does not work well with stranded or tinned stranded wire.I was able to adapt the item by removing the wire terminal clamps and soldering the two wires of my cable to the circuit board for a monophonic mini-3.5 MM jack.None of this was apparent from the product description.
Date published: 2012-08-12
Rated 4 out of 5 by from Great solution for terminating IR cables on platesI have used a bunch of these to provide connections for IR flashers on keystone wallplates behind TV's. They fit in the Leviton plates just fine, and they are 2-conductor, so they mate properly with Xantech and other flashers, which often don't work if connected with stereo 3c jacks.One caveat- it's a bit tricky getting Cat5 cable properly seated in these push-on terminals- make sure you "pull-test" both leads to make sure the spring has a good grip on the wires!
Date published: 2009-01-19
Is this jack equivalent to a 3/32" jack, or is it a standard 1/8" (3.5mm) size?
Asked by: Matchless
Product DetailsWired Home WHIRJ-KJ IR/MP3 Keystone JackThis Wired Home keystone jack is an IR emitter port or an 3.5 mm auxiliary audio jack that fits into any standard Keystone wall plate. Features include spring terminals and a mini jack for simple installation. Standard Cat 5/5e wire can be used for transmitting the IR or audio signals. Accepts up to 22 ga. solid wire.
Answered by: marksteven
Date published: 2014-03-16
Customer projects that include: Wired Home WHIRE-KJ 3.5mm 2-Conductor / Mono Keystone Jack
