Wired Home WHIR3505 Tube Style Wide-Band IR Repeater Target
Brand:|Model: WHIR3505|Part # 182-880
Wired Home's WHIR3505 tube style IR target maintains the aesthetic of a clean, hidden source component installation while keeping you in control. A wide frequency response makes it compatible with nearly every IR product on the market.
List Price$103.99
You Save45%
$57.48
Buy 4+$54.74
Part # 182-880
  • Wide-band 30-100 kHz frequency response
  • Industry standard tube target design
  • Hide an IR target anywhere
  • Fits into a 1/2" hole
  • Compatible with nearly every piece of IR equipment on the market
Many homes today are outfitted with hidden source equipment, be it in cabinets, closets, or the basement. In order to remain in control of your components, an IR distribution system is needed. To maintain décor aesthetics, the engineers at Wired Home have developed the WHIR3505. Wide-band frequency response enables compatibility with nearly every infrared device available on the market, and this IR tube style target is smaller in diameter than a penny. Two target caps; one brass and one plastic, with deep-purple lenses allowing this target to be placed nearly anywhere while remaining unobtrusive. Brass construction ensures durability. With the use of economical Cat 5 cable, this target may be mounted up to 1,000 ft. from an IR hub.
Specifications: • IR frequency bandwidth: 30-100 kHz • Control range: 30 ft. • Reception angle: ±45° off-axis • Dimensions: 0.6" dia x 0.24" L (head), 0.43" dia. x 1.9" L (body) • 6 ft. control cable. Note: Wired Home IR hub, 12 VDC power supply, multi-conductor wire, and Wired Home emitters required for proper operation.
  • Mounting StyleTube Style
  • BrandWired Home
  • ModelWHIR3505
  • Part Number182-880
  • UPC844632070310
  • Product CategoryIR Targets
    (3 Reviews)
  • Weight0.15 lbs.
View similar products to the Wired Home WHIR3505 Tube Style Wide-Band IR Repeater Target
in the IR Targets product category.
Wired Home WHIR3505 Tube Style Wide-Band IR Repeater Target is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Great item!Works great! Won't allow you to program univeral remote if Componets aren't in same room.I couldn't program my universal remote to work the LR's TV which is a LG 47" from the LR Using the IR Target so I took the TV to the basement tried again Works. So in short had to have tv next to Componets to program remote and it all works fine through the IR Target now that it's programmed.
Date published: 2014-08-08
Rated 5 out of 5 by from Works with uverseI use these all the time to replace older targets that are not compatable with Uverse.
Date published: 2014-01-31
Rated 5 out of 5 by from Even works with the X-BoxOur customer has all of his home theater equipment on a rack in a closet below his stairs and wanted to move the video games into the closet as well. For the Wii, we simply punched a hole through the wall and ran the cable back for the IR bar. We installed an IR repeater to control the AV equipment and hoped it would work for the X-Box. We stuck an emitter over the IR sensor (secured with a piece of electrical tape) and crossed our fingers...much to our delight it worked flawlessly! I'm not much of a gamer so we had the customer's son test with Call To Duty. He was playing with two controllers and didn't miss a shot. Way to go Dayton Audio for offering such great IR products!
Date published: 2010-10-21
  • 2016-02-08T06:42CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_182-880, PRD, sort_mostRecent
