Wired Home WHIR2005 Low-Profile Wide-Band IR Repeater Target
Brand:|Model: WHIR2005|Part # 182-876
The WHIR2005 low-profile IR target from Wired Home is designed to provide a control link to remotely located or hidden audio and video equipment, and remain hidden when attached to your flat panel or conventional television.
List Price$48.99
You Save24%
$37.44
Buy 4+$35.29
Part # 182-876
  • Low-profile design virtually disappears
  • Peel-and-stick to the side of an HDTV
  • Wide-band reception for complete IR compatibility
  • Pre-tinned wire termination
  • May be installed up to 1,000 ft. from IR hub using low-cost Cat 5 cable
The WHIR2005 low-profile IR target from Wired Home is designed to provide a control link to remotely located or hidden audio and video equipment, and remain hidden when attached to your flat panel or conventional television. Years of peel-and-stick use is provided from an aggressive adhesive, and the pre-tinned control wire is designed to be connected to low-cost Cat 5 cable for wire runs of up to 1,000 ft. A wide-band design was engineered into the target for compatibility with virtually all existing IR control schemes.
Specifications: • IR frequency bandwidth: 30-100 kHz • Control distance: Up to 30 ft. • Reception angle: Up to ±45° • Dimensions: 0.4" H x 2" W x 0.3" D. Note: Wired Home IR hub, 12 VDC power supply, multi-conductor wire, and Wired Home emitters required for proper operation.
  • Mounting StyleSurface Mount
  • BrandWired Home
  • ModelWHIR2005
  • Part Number182-876
  • UPC844632070297
  • Product CategoryIR Targets
    (6 Reviews)
  • Weight0.12 lbs.
View similar products to the Wired Home WHIR2005 Low-Profile Wide-Band IR Repeater Target
in the IR Targets product category.
