Wired Home WHIR1005 Set Top Wide-Band IR Repeater Target
Brand:|Model: WHIR1005|Part # 182-874
The Wired Home WHIR1005 set top IR target provides an infrared link to your hidden or remotely located audio and video components. A sleek flat black housing integrates well with almost any room décor. Four non-slip rubber feet keep the target in place, even on the slickest of surfaces.
List Price$59.99
You Save24%
$45.89
Buy 4+$43.59
Part # 182-874
  • Receives IR signals for control of hidden A/V equipment
  • Set top design can be placed anywhere an IR target is needed
  • 6 ft. connection cable and non-slip feet
  • Wide band design works with almost all A/V IR commands
  • Receives commands at up to 45° off-axis
The Wired Home WHIR1005 set top IR target provides an infrared link to your hidden or remotely located audio and video components. A sleek flat black housing integrates well with almost any room dÉcor. Four non-slip rubber feet keep the target in place, even on the slickest of surfaces. Compatibility with the widest range of products (including late model cable and satellite receivers) has been ensured through the use of a wide band design that receives IR bands between 30-100 kHz. Built into the housing is a confirmation LED that aids in system troubleshooting by blinking whenever the target receives a command. Pre-installed onto the WHIR1005s 6 ft. connection cable is a stereo plug for connection to a Wired Home WHIRJ-KJ keystone jack, which then is wired to a Wired Home WHIRH, WH4IR, or WHIRDH IR hub. Alternatively, the 3.5 mm stereo plug may be removed for direct connection to a Wired Home IR hub. The white wire (tip) carries the IR signal; the red wire (ring) is ground, and the shield (sleeve) carries 12 VDC power.
Specifications: • IR frequency bandwidth: 30-100 kHz • Control distance: 20 ft. • Reception angle: Up to ±45° • Dimensions: 1-1/8" H x 4" W x 2-1/8" D. Note: Wired Home IR hub, 12 VDC power supply, multi-conductor wire, and Wired Home emitters required for proper operation.
  • Mounting StyleSet-Top
  • BrandWired Home
  • ModelWHIR1005
  • Part Number182-874
  • UPC844632070280
  • Product CategoryIR Targets
    (2 Reviews)
  • Weight0.4 lbs.
View similar products to the Wired Home WHIR1005 Set Top Wide-Band IR Repeater Target
in the IR Targets product category.
