182-886_ALT_0
182-886_ALT_1
Wired Home WHHCPS High Current Power Supply 12 VDC 1.2A
Brand:|Model: WHHCPS|Part # 182-886
Wired Home engineered the WHHCPS power supply to overcome the voltage sag that occurs in IR distribution systems from increased resistance due to long wire runs. A state-of-the-art, self-regulated switching design was chosen for its small size and efficient use of power.
List Price$11.99
You Save27%
$8.80
Buy 4-49 $8.25
Buy 50+$7.45
Part # 182-886
  • Self-regulating, switching design provides a stable 12 VDC output
  • Wide range voltage input 100 to 240 VAC
  • Small non-polarized housing doesn't waste space
  • High current output overcomes resistance on long wire runs
Wired Home engineered the WHHCPS power supply to overcome the voltage sag that occurs in IR distribution systems from increased resistance due to long wire runs. A state-of-the-art, self-regulated switching design was chosen for its small size and efficient use of power. A non-polarized plug enables the power supply to be plugged-in right side up or upside down without taking up adjacent outlets on a power strip. This power supply is UL listed in the USA and Canada. It is also CE rated and RoHS compliant.
Specifications: • Power input: 100 to 240 VAC, 47-63 Hz • Power output: 12 VDC, 1.2A • Plug type: 2.1 mm ID x 5.5 mm OD • Polarity: Center positive • 6 ft. power cord • Dimensions: 2-5/8" H x 1-5/8" W x 2-1/8" D.
  • DC Output Voltage12V
  • Current Capacity1200 mA
  • Center/Tip PolarityCenter (+)
  • Plug Size2.1 x 5.5 mm
  • Input Voltage100~240 VAC
  • BrandWired Home
  • ModelWHHCPS
  • Part Number182-886
  • UPC844632070341
  • Product CategoryAC/DC Power Adapters
    (1 Reviews)
  • Weight0.28 lbs.
View similar products to the Wired Home WHHCPS High Current Power Supply 12 VDC 1.2A
in the AC/DC Power Adapters product category.
Wired Home WHHCPS High Current Power Supply 12 VDC 1.2A is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Great Low-Cost Power SupplyGreat Low-Cost Power Supply.
Date published: 2009-03-17
  • 2016-02-11T06:47CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_182-886, PRD, sort_mostRecent
Could you advise the Model # of Power Supply needed for the Ki8nter MA600 mini amp - tuner and what the cost would be for said PS. Thank You, Robert E. Lampione
Asked by: Champione
This amp can operate on any supply that is capable of supplying between 9 and 14.4 volts and 1 to 3 amps. This does fall in that range and also uses the correct size connector so it would be a good choice for that application.
Answered by: Chrisf
Date published: 2016-01-27
I need a replacement for a class2 power supply 120V 60Hz 28W output 12V-1800mA efficiency level 4, do you have one that would work for me?
Asked by: MRDon
Date published: 2015-12-15
Is this power supply safe to use with a Focusrite Saffire Pro 14 audio interface? The Focusrite specs are Input AC 100-240V, 50/60 hz, 0.35A; Output: 12 VDC 1250mA, center pin positive. On the unit it has 12V DC IN, 15W max. No listing of the plug size.
Asked by: Surf123
The specifications provided seem to match, but we would need to know what the plug size is to be certain. Unfortunately, we do not have a cross reference available for this type of thing. Please contact our tech support for more help with this question, tech@parts-express.com or 800-338-0531 x1.
Answered by: GregT
Date published: 2015-05-04
will p/n 182-886 power supply work with above radio # 310-374 for correct d/c power input?
Asked by: fred351
Yes this will work with that amplifier.
Date published: 2015-03-18
  • 2016-02-11T07:31CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_182-886, PRD, sort_recentQuestionsFirst
