Wired Home WHDVIR100 Digital Speaker Volume Control White
Brand:|Model: WHDVIR100|Part # 182-872
Wired Home's innovative WH-DVIR100 digital volume control makes distributed audio management affordable, while providing impedance protection for up to 16 pairs of speakers (when used with 7 other volume controls).
List Price$169.99
You Save24%
$129.70
Buy 4+$125.45
Part # 182-872
  • Digital volume trimming with blue LED display
  • 100W RMS per channel power handling
  • Stereo impedance matching for up to 16 pairs of speakers
  • Built-in IR target and backlighting
  • Remote control included
Wired Home's innovative WH-DVIR100 digital volume control makes distributed audio management affordable, while providing impedance protection for up to 16 pairs of speakers (when used with 7 other volume controls). Volume may be controlled by the included IR remote control or by the backlit push-button keypad. A cool blue LED display presents the exact volume setting, no need to guess. System component control is achieved through the integrated IR target that is compatible with 38 kHz and 56 kHz IR systems (IR hub, power supply, and emitter sold separately). The OFF/MUTE button quickly silences the local audio zone for when the phone or doorbell rings, and the last volume setting is remembered. Installation could not be any easier. Removable phoenix-type speaker input and output connectors, for pre-wiring, accommodate up to 14 AWG wire. Power and IR signal connection is accomplished through the RJ45 jack—wiring standard T-568B—which connects to the Wired Home WH-IRH IR Hub (up to 8 controls per hub). Tired of losing impedance setting jumpers? A single switch allows you to set and forget the protection. Single-gang packaging and white Decora® styling blends in nicely with any room.
  • TypeDigital
  • Control SurfacePush-button
  • Wall Plate ColorWhite
  • BrandWired Home
  • ModelWHDVIR100
  • Part Number182-872
  • UPC844632065828
  • Product CategoryIn-Wall Volume Controls
    (2 Reviews)
  • Weight2.1 lbs.
Wired Home WHDVIR100 Digital Speaker Volume Control White is rated 4.0 out of 5 by 2.
Rated 4 out of 5 by from good productHello the product bought from you responded correctly to my expectations both technical and aesthetic.The delivery was quick.good service.thanks
Date published: 2014-03-26
Rated 4 out of 5 by from Really clean lookVolume controller worked great. Really wish the remote that came with it worked also
Date published: 2009-03-16
  • 2016-02-11T06:47CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_182-872, PRD, sort_mostRecent
How many pairs of speakers can one unit control?
Asked by: Nageelum
This is design to control one pair of speakers but you can use up to 8 volume controls for up to 16 individual speakers.
Date published: 2016-01-13
Can this be powered from Ethernet port? I cannot see a power connection on it? My plan is to put this in bedroom for my in ceiling speakers and have the ir codes programmed into my harmony. But I have a standard Yamaha receiver than is powering house.
Asked by: biscuit985
The Ethernet port on this volume control will also carry the power. You can refer to the user manual in the Manuals / Resources section of the web page.
Answered by: PE Tom
Date published: 2015-08-14
does this need a power supply if we don't need IR connection?
Asked by: Frank L.
Yes this does require 12vDC for operation even without the use of IR. You can insert a 12vDC power supply by using BR/W-BR as the 12v positive and BL/W-GR as negative on an RJ45 jack.
  • 2016-02-11T07:31CST
  • loc_en_US, sid_182-872, PRD, sort_recentQuestionsFirst
