Wired Home WH4IR 4 Port IR Distribution Module
Brand:|Model: WH4IR|Part # 182-832
If you are planning on distributing audio and video throughout the house, you will need a way to control your components remotely. Wired Home should be at the top of your list for IR control, and the WH-4IR is the hub of the IR system.
List Price$123.99
Regular Price$94.72
You Save49%
Sale Price
$48.00
Part # 182-832
  • Spring-loaded, push terminals for easy connection
  • Structured wire enclosure mounting tabs
  • Expansion port for daisy chaining hubs
  • Independent target adjustments
  • Compatible with nearly all IR systems
If you are planning on distributing audio and video throughout the house, you will need a way to control your components remotely. Wired Home should be at the top of your list for IR control, and the WH-4IR is the hub of the IR system. Installation is simple and easy when installing inside of a structured wire enclosure. Spring-loaded, push terminals on the 4 target inputs and 4 emitter outputs facilitate the use of Cat 5 or control cable without the need for RJ45 or 3.5 mm connectors. Individual room sensitivity adjustment control helps to compensate for unique lighting situations. Also engineered into the hub is an expansion port for daisy chaining endless hubs. Pain-free troubleshooting is accomplished through use of the on-board "activity" LED. Dimensions: 2-7/8" H x 6-1/4" W x 1-1/8" D. 12 VDC, 500 mA switch-mode power supply included.
  • BrandWired Home
  • ModelWH4IR
  • Part Number182-832
  • UPC844632003035
  • Product CategoryIR Engines / Hubs
    (2 Reviews)
  • Weight1.04 lbs.
View similar products to the Wired Home WH4IR 4 Port IR Distribution Module
in the IR Engines / Hubs product category.
