Wired Home WH3X8IR 3x8 RF Distribution Amp with IR HUB
Brand:|Model: WH3X8IR|Part # 182-817
Wired Home designed the WH3X8IR for efficient distribution of RF signals (as well as infrared control) to eight different locations. An internal unity gain amplifier maintains a noise-free output signal. Two additional F-connector coaxial inputs allow for the insertion of modulated signals.
  • 50 MHz to 860 MHz RF amplifier bandwidth
  • Bi-directional for use with cable modem and pay-per-view services
  • Two F-connector coaxial inputs for the addition of modulated video signal
  • IR compatible for remote control throughout the house
  • Fits Wired Home structured wiring enclosures
Wired Home designed the WH3X8IR for efficient distribution of RF and broadband signals to eight different locations. An internal unity gain amplifier maintains a noise-free output signal, even over long runs. Two additional F-connector coaxial inputs allow for the insertion of modulated signals such as a front door camera, DVD, or a nursery camera into your RF distribution system. Bi-directional capability provides a return path for cable modem, digital cable and pay-per-view services. Additionally, a built-in IR hub allows for remote control of source devices without the need to run additional wires. Simply connect a coax compatible set-top target for IR control to all desired rooms. The IR output can be connected to another IR hub or directly to a source device using a standard IR emitter with 3.5mm plug.
Specifications: • RF amplifier gain: +3 dB • Reverse path attenuation: -1.5 dB • Dimensions: 3-1/4" H x 5-3/4" W (6-1/4" W with brackets) x 3-3/8" D. Power supply is included.
  • BrandWired Home
  • ModelWH3X8IR
  • Part Number182-817
  • UPC844632070648
  • Product CategoryRF Distribution / Amplifiers
  • Weight2.23 lbs.
View similar products to the Wired Home WH3X8IR 3x8 RF Distribution Amp with IR HUB
in the RF Distribution / Amplifiers product category.
