182-820_ALT_0
182-820_ALT_1
182-820_ALT_2
182-820_ALT_3
182-820_ALT_4
182-820_ALT_9
Wired Home WH10SDH 10 Room Speaker Distribution Hub
Brand:| Model: WH10SDH
Up to 10 pairs of speakers can be connected to an audio source using the WH-10SDH, without the need for speaker switching devices. Each channel is designed to handle up to 200 watts max. Must be used with used with impedance matching volume controls.
  • High power handling of 10 x 200 watts max
  • Removable speaker outputs accept up to 14 AWG wire
  • 5-way binding post amplifier inputs accept up to 10 AWG wire
  • Designed to snap-in to a Wired Home enclosure
182-820
Weight: 1 lbs.
IN STOCK
List Price$89.99
You Save24%
$68.63
Buy 4-up$65.37
Part # 182-820
Up to 10 pairs of speakers can be connected to an audio source using the WH-10SDH, without the need for speaker switching devices. Removable wire connectors, which accept up to 14 AWG wire, allow an installer the freedom to pre-wire before sheet rock installation which reduces the risk of damage to the distribution panel. After the sheet rock is installed, the connectors snap quickly into place. Each channel is designed to handle up to 200 watts max. Large 5-way binding post inputs accept up to 10 AWG wire from the amplifier output. Engineered for Wired Home enclosures, but will fit most other structured wiring panels. Must be used with used with impedance matching volume controls. Dimensions: 2-7/8" H x 6-1/4" W x 1-1/8" D.
  • BrandWired Home
  • ModelWH10SDH
  • Part Number182-820
  • UPC844632016974
  • Product CategorySpeaker Distribution
    (1 Reviews)
  • Weight1 lbs.
View similar products to the Wired Home WH10SDH 10 Room Speaker Distribution Hub
in the Speaker Distribution product category.
Wired Home WH10SDH 10 Room Speaker Distribution Hub is rated 5.0 out of 5 by 1.
Rated 5 out of 5 by from Great productPutting it in my enclosure was very easy. I have 4 room so far hooked to it with Dayton altra seires speakers and matching volume controls. I ran 14 gauge speaker wire and connecting the wire to the connectors was easy. In the future I plan on connecting 2 more pair the the unit.
Date published: 2008-05-14
  • 2015-04-27T08:43CST
  • co_hasreviews, tv_0, tr_1
  • loc_en_US, sid_182-820, PRD, sort_mostRecent
I need a Bluetooth capable amplifier to power this speaker distribution device. Trying to connect 8 speakers in my RV. I have 110 ac outlets available.
Asked by: Jawilson1947
I have some rooms in a commercial setting with 6 or more speakers in them.  I want the volume control to work for all 6.  Can I use a hub for each room and put the impedance matching volume control on the input side?
Asked by: ruskinmiller
No. Impedance matching volume controls are designed to work properly with only one pair of speakers on each.
Date published: 2014-12-02
Trying to expand my listening, put a pair of speakers in my bed room with a separate volume controle. My receiver is a surround sound. My question is don't know witch set of speakers to come off from in the living room front rear or center channel. I
Asked by: Powerhouse11
Date published: 2014-12-01
Can I use this to connect 14-Speakers ceiling, Bose FreeSpace DS 16F loudspeakers? The Long-Term Power Handling = 16 W (64 W peak) and Nominal Impedance = 8 Ω (transformer bypassed) on those speakers?
Asked by: YIbrahim
Yes, but this will not provide any impedance protection. It is designed to work with impedance matching volume controls, one on each pair of 8 ohm speakers.
Date published: 2014-11-20
Will it accept 12 AGW wire, which is thicker, but a lower number than 14 AGW wire that is is supposed to accept "up to".
Asked by: Vince53
The largest gauge these will accept is 14, "up to" refers to the gauge size, not the number. The binding posts will accept up to 10 gauge.
Date published: 2014-08-02
What volume controls work with this unit?
Asked by: GeorgeH
This will work with any impedance matching volume control.
Date published: 2014-07-15
  • 2015-04-27T10:39CST
  • co_hasquestionsanswers, tq_7
  • loc_en_US, sid_182-820, PRD, sort_recentQuestionsFirst
Customer projects that include: Wired Home WH10SDH 10 Room Speaker Distribution Hub
