Wired Home VRS100 Impedance Matching Rotary Speaker Volume Control 100W
Brand:|Model: VRS100|Part # 300-552
Wired Home's VRS100 impedance matching stereo volume control has been redesigned to incorporate premium grade autoformers, subtle aesthetics, three color options, and improved phoenix-type connectors.
List Price$54.99
Regular Price$39.75
You Save30%
Sale Price
$28.00
Part # 300-552
  • 100 watt/channel power handling
  • Three wall plate color options included
  • Improved phoenix-type connections
  • Decora styling and subtle aesthetics
Wired Home has redesigned their time proven, impedance matching, stereo volume control for greater durability and aesthetic appeal. Only premium grade autoformers are used for high power handling, rock solid reliability, and wider frequency response. White, ivory, and almond Decora style wall plates and inserts are now included in a single package. For aesthetic purposes, the speaker logo is now embossed for a subtle look. Installers will love the new phoenix-type connectors that offer ease of installation.
Specifications: • Power handling: 2 x 100 watts max • Input/output wire AWG terminal size: Up to 14 AWG • Impedance protection: Up to 16 pairs of 8 ohm speakers • Dimensions: 4-1/8" H x 1-1/2" W x 3" D (in wall depth 2-3/4") • Sold individually.
  • TypeImpedance Protected
  • Control SurfaceRotary Knob
  • Wall Plate ColorWhite
  • BrandWired Home
  • ModelVRS100
  • Part Number300-552
  • UPC844632063466
  • Product CategoryIn-Wall Volume Controls
    (16 Reviews)
  • Weight1.5 lbs.
View similar products to the Wired Home VRS100 Impedance Matching Rotary Speaker Volume Control 100W
in the In-Wall Volume Controls product category.
Wired Home VRS100 Impedance Matching Rotary Speaker Volume Control 100W is rated 4.375 out of 5 by 16.
Rated 5 out of 5 by from Performs as advertisedLooked at the big box stores for this same item, and saved 50%.... Easy install and performs well.
Date published: 2014-02-10
Rated 4 out of 5 by from Very GoodWould buy again
Date published: 2009-11-06
Rated 5 out of 5 by from Works Well, Easy to InstallThis item was easy to install. The Phoenix connectors made it convenient. While the unit was a tight fit in a standard electrical box, it was not terribly difficult to fit it in. Just don't leave too much excess wire in the box.The control works well and does not seem to affect the sound quality.
Date published: 2009-03-25
Rated 5 out of 5 by from FantasticVolume controls work great!I like the different colored plates sent. So If i repaint room to different color, i can change wall plates too without paying more.
Rated 5 out of 5 by from Best bang for the BuckI have used the older model for years, they have never failed. This new model comes with all the color covers posiable so if Mommy what white you have it if she changers mind to Ivory you have it if she want's bone or off white you have it covered. Huskerfan must be a rookie and Single with out kids.
Date published: 2009-03-23
Rated 4 out of 5 by from good stuffBeucause of the value I've used these on several homes I've install enviromental sound systems on. Used the same on my owne home becuase of the quality. Thanx
Date published: 2009-02-23
  • 2016-02-11T06:40CST
  • co_hasreviews, tv_0, tr_16
  • loc_en_US, sid_300-552, PRD, sort_mostRecent
I just bought a MSS6 speaker selector on 4 pairs of speakers.I ran shieled 18ga solid wire to the speakers.Prior to purchasing the speaker selector I connected 2 pairs of wall volume controls, it burned up the amp. Will ur volum controls solve my issue?
Asked by: Diamond Dave
I see that three different colored wall plates are provided. Does this mean the insert and dial are only available in one color, white? Or can you get the insert and dial in one of the other colors, ivory or almond? (Similar to a light switch)
Asked by: snakedoc
This includes covers, inserts and dials for all three color options.
Date published: 2014-10-27
hi, please clarify ,what is the purpose of those  jumpers X1, X2 etc
Asked by: proarun
The jumpers need to reflect the number of volume controls in the system. For example, with one control it will stay on x1, with two it will need to be moved to x2, etc.
Date published: 2014-09-04
Looking to wire two sets of 8ohm speakers to a receiver, one direct and the second through this volume control.  If the desired impedance at the receiver is 6-10ohms (preferably 6-8) how would you jumper the VRS100 switch (1x, 2x, 4x, 8x) ?
Asked by: tpremo
With only one volume control the jumper needs to be on 1x.
Date published: 2014-05-22
Question regarding the impedance match?
What load is seen by the amplifier? If I run parallel speaker wires from an amp to 4 of these units, what will be the load seen by the amp? If it is a typical resistive load what is the rating for each volume control? Thanks.
Asked by: JAudio
Assuming all 8 ohm speakers, the load seen by the amplifier can be anywhere between 4-8 ohms.
Date published: 2013-07-05
Please clear up label circuit board confusion
What label is correct? Circuit board or Amp/Speaker Connection label?
Asked by: warofman
The sticker and circuit board labels should be the same front to back. There is a possibility the sticker was installed upside down. In this case follow the circuit board labels.
Date published: 2013-02-05
  • 2016-02-11T07:20CST
  • co_hasquestionsanswers, tq_10
  • loc_en_US, sid_300-552, PRD, sort_recentQuestionsFirst
