Wired Home VR60S Sliding Audiophile Grade Speaker Volume Control 60W
Brand:|Model: VR60S|Part # 300-554
Wired Home proudly presents the VR60 series resistor-based volume controls. Only audiophile-quality wire wound non-inductive resistors are introduced to the signal path between the amplifier and speakers. Highs remain crystal clear; lows are kept tight and accurate.
List Price$50.99
You Save24%
$38.84
Buy 6+$36.85
Part # 300-554
  • Only audiophile-grade resistors attenuate the sound
  • Wide-band frequency response without transformer roll-off
  • Three Decora style wall plate color choices included
  • Phoenix type removable connectors
Wired Home proudly presents the VR60 series resistor-based volume controls. No longer does the demanding audio enthusiast have to settle for the frequency roll-off inherent with transformer-based volume controls. Only audiophile-quality wire wound non-inductive resistors are introduced to the signal path between the amplifier and speakers. Highs remain crystal clear; lows are kept tight and accurate. White, ivory, and almond wall plate sets are included. Phoenix-type removable connectors are used to facilitate a simple installation process.
Specifications: • Power handling: 2 x 60 watts max • Input/output wire AWG terminal size: Up to 14 AWG • Dimensions: 4" H x 1-1/2" W x 2-5/8" D (depth in wall 2-1/8").
  • TypeResistor Based
  • Control SurfaceSliding Mechanism
  • Wall Plate ColorWhite
  • BrandWired Home
  • ModelVR60S
  • Part Number300-554
  • UPC844632063473
  • Product CategoryIn-Wall Volume Controls
    (4 Reviews)
  • Weight0.6 lbs.
View similar products to the Wired Home VR60S Sliding Audiophile Grade Speaker Volume Control 60W
in the In-Wall Volume Controls product category.
Wired Home VR60S Sliding Audiophile Grade Speaker Volume Control 60W is rated 4.75 out of 5 by 4.
Rated 5 out of 5 by from Good Volume ControlGood slide, easy to install and works much better (i.e., better sound) than my previous volume controller.
Date published: 2015-03-10
Rated 4 out of 5 by from VR60S Audio ControlFirst, the unit works great and performs flawlessly. No problem with the functionality. However, was a bit surprised at the lack of protection afforded the circuit board behind the unit. The entire PCB and components on that board are exposed. I mounted them (3) in open boxes in the wall so I don't think that I'll have a problem but it will be a wait and see.
Date published: 2011-12-27
Rated 5 out of 5 by from High Quality Volume ControlThis is a great speaker control - I had read in many previous posts how deep it is - and they are correct. I always recommend using open backed boxes for speaker wire where you can (in MN you can use these on any interior walls) and this won't be a problem at all. Because I put one of these on an outside wall I did get the opportunity to put it in a closed back single gang box as well and it fit just fine - just had to reduce how much extra wire I left - and it was a tight fit. Overall I prefer this over the circular dial volume as it clicks into place at the various volume levels. It came with all of the faceplats, slides, etc in all the colors as well for you to choose which one to match your other switches/outlets. Great product!
Date published: 2009-01-19
Rated 5 out of 5 by from Great Volume ControlNice volume control! Like the slide switch that "clicks" on the volume levels. Works great! Good quality.
Date published: 2008-12-17
  • 2016-02-14T06:43CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_300-554, PRD, sort_mostRecent
are these units placed inline between the amp and the speakers?
Asked by: kirbymart123
Yes.
Date published: 2015-07-21
Is this a powered solution? Looking to power a passive speaker with this wall switch. Will this do it, or do I need an amp also?
Asked by: jackie273
This is a passive control, an amplifier will need to be used with this in order to power a speaker.
Date published: 2015-06-15
Upgraded to an Onkyo NR 808 with three zone capability. Zones 1 and 2 power one set of speakers, all good there.  Zone three gets distributed to three sets of spkrs. with these switches.  Jumpers are on X4, terrible sound from Zone 3. Previously worked.
Asked by: Bres
Date published: 2014-08-04
Also-when volume at minimum, is it true 'off'....or just very very low?
Asked by: slevy951
Minimum volume on these controls is very low but not completely off.
Date published: 2014-05-30
Can this use Decora style trim plates?
Asked by: slevy951
This does work with most standard Decora type faceplates.
Answered by: Chrisf
Date published: 2014-06-02
Hi, in its User's Manual required Dayton Audio multi-speaker distribution,
I do not have it but I do have Niles SSVC-6 Speaker Selector.Can I use this VR60s volume control without Dayton Audio multi-speaker distribution ?
Asked by: vfr750z28
Yes this will work with an speaker selector regardless of brand.
Date published: 2013-05-20
  • 2016-02-14T07:57CST
  • co_hasquestionsanswers, tq_6
  • loc_en_US, sid_300-554, PRD, sort_recentQuestionsFirst
