Wired Home SS4 Speaker Selector Impedance Matching 1 In 4 Out
Brand:|Model: SS4|Part # 300-970
The SS4 is a low-profile speaker selector that allows you to distribute a stereo speaker-level (amplified) signal to multiple listening zones. These speaker selectors feature a manually activated impedance protection circuit.
List Price$38.99
You Save23%
$29.90
Buy 2+$28.95
Part # 300-970
  • Manual impedance matching protection circuit
  • Accommodates up to 14 AWG speaker wire
  • Loop-through output from the source amplifier
  • Select any one or all of your connected speakers
The SS4 is a low-profile speaker selector that allows you to distribute a stereo speaker-level (amplified) signal to multiple listening zones. These speaker selectors feature a manually activated impedance protection circuit. The protection switch can be turned ON to prevent the impedance to your amplifier from dropping below 5 ohms, regardless of the number and impedance ratings of your speakers. The protection switch can be turned OFF when used as part of a system incorporating impedance matching volume controls, allowing you to get the most out of your amplifier.
The terminals on the rear of the speaker selector will accommodate up to 14 gauge cable; sufficient for cable runs exceeding 100 feet. For shorter distances, 16 ~ 18 gauge cable will suffice. For in-wall installations, we recommend using CL-2 or CL-3 rated cable for compliance with local building codes. If unsure, contact you local building inspector. When connecting a speaker and amplifier, it is important to maintain polarity; positive (+/red) to positive and negative (-/black) to negative. Be careful to maintain correct polarity between the amplifier, the speaker selector, the volume controls and the speakers. Power: 70 watts/channel impedance protection off, 140 watts/channel impedance protection on. Dimensions: 8-1/2" W x 2-1/8" H (with feet) x 5" D (including wire terminals and push buttons).
  • Inputs (Source)Single (1 Pair)
  • Speaker Outputs4 Pair
  • Volume ControlNo
  • BrandWired Home
  • ModelSS4
  • Part Number300-970
  • UPC844632080241
  • Product CategorySpeaker Selector Switches
    (21 Reviews)
  • Weight2.44 lbs.
View similar products to the Wired Home SS4 Speaker Selector Impedance Matching 1 In 4 Out
in the Speaker Selector Switches product category.
Wired Home SS4 Speaker Selector Impedance Matching 1 In 4 Out is rated 4.7143 out of 5 by 21.
Rated 5 out of 5 by from Looks Great and Works wellI purchased this unit and it works great. I have speakers all over my house using automotive car stereo speakers ( cost less) and they work great. Music every where..
Date published: 2015-10-10
Rated 4 out of 5 by from Descent ProductIf you are looking for variability in how your system sounds and want to be able to turn on/off speakers in select loctaions theis speaker switcher is going to be a pretty good fit.
Date published: 2015-05-28
Rated 5 out of 5 by from Awesome little device!This is my second purchase of this exact device. The first one works flawlessly and is still in use in my garage. I needed the same thing inside for a stereo that didn't have three zones. It instantly adds an extra zone to wherever you need it. It doesn't harm the speakers because of the optional protection built in it. You can't go wrong. I highly recommend it. Works great and priced right.
Date published: 2015-05-07
Rated 5 out of 5 by from Easy to install, works greatI bought a month ago to switch between studio monitors. This a great option to add a second set of speakers without buying another amp. So far, it works great. All metal construction. Very solid build.
Date published: 2015-04-22
Rated 5 out of 5 by from Just what I neededI bought this to allow 2 different sets of speakers to be driven from 1 receiver/amp without the fear of damaging the amp. It works perfectly. Thanks P/E for having specialty parts that I need at a very reasonable price.
Date published: 2015-02-17
Rated 5 out of 5 by from Works perfectlyVery well sturdy and well made. Very fast shipping as always.
Date published: 2015-01-06
  • 2016-02-13T06:33CST
  • co_hasreviews, tv_0, tr_21
  • loc_en_US, sid_300-970, PRD, sort_mostRecent
When not in protection mode is this a straight through device? When not in protection mode are all the outputs on a channel ganged in parallel?
Asked by: craigsmithx
They are indeed in parallel, but this uses transformers so they are technically not a straight through,
Answered by: Chrisf
Date published: 2016-02-12
I currently have an AR1104 unit that seems to cut out the right channel in a couple of rooms. It's probably 15 years old anyway.  I am using it with 4 ohm Bose wall speakers and wall volume controls.  Any issues with using volume controls?
Asked by: Jim De Young
You can use this with volume controls, but you should turn off the impedance protection if they are impedance matching volume controls.
Answered by: Chrisf
Date published: 2016-02-10
I am installing Bose amplifier and 4 speakers, (2 in each room). I understand the input (I take this is for the output from the amplifier) I see the speaker selectors. What is the output for. I need installation instructions
Asked by: Pete 67
The output on these selectors is a pass-through of the input. This is used in case you want to have a pair of speakers wired to the main output of the amplifier and not have a mess of cables. You can see the manual for the selector below.www.parts-express.com/pedocs/manuals/wired-home-speaker-selectors-ss4-ss6-ss8-manual.pdf
Date published: 2015-01-19
is the impedance protection on when the button is pushed in?
Asked by: Tim92
Yes, Press the button in for the Impedance protection.
Answered by: TomI
Date published: 2014-12-16
Would it be safe to also use remote volume control with this?
Asked by: audiodork
Date published: 2014-09-05
What are the dimensions of this unit?
Asked by: Oneshot
Date published: 2014-07-28
  • 2016-02-13T07:29CST
  • co_hasquestionsanswers, tq_17
  • loc_en_US, sid_300-970, PRD, sort_recentQuestionsFirst
