Wired Home SKRL-12-100 12 AWG OFC Speaker Wire 100 ft.
Brand:|Model: SKRL-12-100|Part # 100-025
Wired Home's SKRL speaker wire is designed to complement any high-end audio system. Features a clear, flexible PVC insulation and OFC configured in a rope-lay configuration to minimize skin effect. 12 AWG, 100 ft spool.
List Price$101.99
You Save61%
$39.44
Buy 4+$36.26
Part # 100-025
  • 259 x 36 AWG wire construction
  • Guarantees maximum power transfer and high damping factor
  • High-density rope lay copper stranding for superior flexibility and electrical efficiency
  • Durable, pliable clear PVC insulation withstands abuse
  • Extremely low capacitance and inductance
  • Polarity ridge for easy polarity identification even in low light
Wired Home's SKRL speaker wire is designed to complement any high-end audio system. Oxygen free copper (OFC) is configured in a rope-lay configuration to minimize skin effect which causes high frequency roll-off. Clear, flexible PVC insulation withstands abuse and is rated up to 140°F (60°C). The primary identifying polarity feature for the Wired Home OFC Speaker Cable is a ridge on the outer edge of one conductor. Feeling for the ridge allows you to easily identify the polarity even in low light conditions. Construction: 259 strands x 36 AWG per conductor. Also available in 100 and 500 ft. rolls and 10, 14, and 16 AWG.
  • Wire Gauge12 AWG
  • # of Conductors2 Conductor
  • Jacket ColorClear
  • Length100 ft.
  • BrandWired Home
  • ModelSKRL-12-100
  • Part Number100-025
  • UPC844632055362
  • Product CategorySpeaker Wire
  • Unit of MeasureRL
    (28 Reviews)
  • Weight5.38 lbs.
View similar products to the Wired Home SKRL-12-100 12 AWG OFC Speaker Wire 100 ft.
in the Hi-Fi Speaker Wire product category.
Wired Home SKRL-12-100 12 AWG OFC Speaker Wire 100 ft. is rated 4.5357 out of 5 by 28.
Rated 4 out of 5 by from 12 Gauge speaker wireGood wire for the price but looks more like 14 gauge than 12 gauge. It is about half the diameter of my audiophile grade Apature 12 gauge wire.
Date published: 2015-03-30
Rated 4 out of 5 by from Great wireThis wire is the best I've come across so far for speaker building. Splices, strips, and unfolds without kinks. Very conformable, yet durable. It would be nice to have a better-defined polarity across one of the wires, but this is a minor issue (that is becoming quite annoying). Fine wires, clean copper, and clean wire "braiding" make this great stuff. I strip away about 80% of the outer wire strands to connect them into insulated blue crimp terminals. 4/5 stars to improve polarity recognition!
Date published: 2015-03-03
Rated 5 out of 5 by from DIY'erProduct is very good quality, product installed and performed as planned, recommend for long cable runs, would recommend and purchase again
Date published: 2015-01-15
Rated 5 out of 5 by from Great Sound!I installed the Wired Home 10 gage speaker wire to my music room speakers and was so pleased with the sound that I bought the Wired Home 12 gage to less-current demanding kitchen speakers. Each cable is fed by those extremely clean Behringer INUKE amps (INUKE3000 and INUKE1000, respectively. The 12g a is equally good.
Date published: 2014-09-29
Rated 3 out of 5 by from 12 Ga Speaker wireVery flexible, Not super easy to determine the + from -, the black printing down one wire is not real bold. But heavy duty - Yet flexible.
Date published: 2014-05-15
Rated 4 out of 5 by from wireits just that nothing more nothing less used for automotive speakers 4 20ft runs no resistance. it's exactly as labeled 100% copper speaker wire
Date published: 2014-04-25
  • 2016-02-08T06:49CST
  • co_hasreviews, tv_0, tr_28
  • loc_en_US, sid_100-025, PRD, sort_mostRecent
What is the actual AWG gage of your 12 AWG, some said, it is actually smaller? Also I only count 105 strands per side, total of 210 vs your spec of 259 in your spec sheet? Thanks, Sid
Asked by: Sid13
I need speaker wire but the wire I have is labeled ofhc and your wire is ofc. What's the H? It also has SP12 (the gauge?) and awd 12(style?) on it.
Asked by: BobinMN
OFHC is oxygen free high thermal conductivity wire. It doesn't really help or hurt in audio applications though since heat is not an issue in speaker systems. The other markings are probably manufacturer listings and could indicate the gauge.
Answered by: Chrisf
Date published: 2015-03-23
Can anyone verify this IS copper wire and NOT CCA wire? CCA = Copper clad Aluminum
Asked by: JerryZ19957
This is made from standard 99.999% OFC copper.
Will this stand up to outdoor installations?
Asked by: MrKaffee
This jacketing is not rated for outdoor use so I would not recommend it for such. It would probably become brittle and start to break apart causing a short in the conductors and possible damaging audio components after a short period of time.
  • 2016-02-08T07:26CST
  • co_hasquestionsanswers, tq_4
  • loc_en_US, sid_100-025, PRD, sort_recentQuestionsFirst
