Wired Home OVC100GR Outdoor Speaker Impedance Matching Volume Control 100W Gray
Brand:|Model: OVC100GR|Part # 300-564
Leaving the outdoor fun to adjust speaker volume—song to song—is a thing of the past; the OVC100GR places control right at your fingertips. Features include 12-step volume attenuation and a completely sealed housing to prevent damaging moisture from entering into the volume control.
List Price$70.99
You Save24%
$53.98
Buy 4+$51.41
Part # 300-564
  • Control your outdoor audio system outside…where the fun is
  • All weather sealed housing
  • 100W per channel power handling
  • 4-position impedance matching switch
  • Phoenix-type removal speaker terminals accept up to 14 AWG wire
Once you have an installed an outdoor audio system you'll wonder how you went so long without it. The same goes for the Dayton Audio outdoor volume control. Leaving the outdoor fun to adjust speaker volume—song to song—is a thing of the past; the OVC100GR places control right at your fingertips. Features include 12-step volume attenuation, a completely sealed housing to prevent damaging moisture from entering into the volume control, a four-position impedance matching switch, 100 watt per channel power handling, and a rubberized speaker wire feed through gasket. Mount the OVC100GR to your deck using the screw mount tabs, or pole mount it using 1-1/4" conduit. Dimensions: 5" H (including 1/2" H x 1-1/4" dia. pole mount flange) x 3-3/4" (including two 1/2" W mounting tabs) x 4-1/2" D (including 1/2" H x 1-1/4" dia. volume knob. Gray housing.
  • TypeImpedance Protected
  • Control SurfaceRotary Knob
  • Wall Plate ColorGray
  • BrandWired Home
  • ModelOVC100GR
  • Part Number300-564
  • UPC844632072864
  • Product CategoryIn-Wall Volume Controls
    (5 Reviews)
  • Weight1.6 lbs.
View similar products to the Wired Home OVC100GR Outdoor Speaker Impedance Matching Volume Control 100W Gray
in the In-Wall Volume Controls product category.
Wired Home OVC100GR Outdoor Speaker Impedance Matching Volume Control 100W Gray is rated 4.4 out of 5 by 5.
Rated 5 out of 5 by from well builtWorks like it should. Well built and well sealed enclosure.
Date published: 2014-06-16
Rated 4 out of 5 by from Good and simple VCIts a simple, rugged, and affordable exterior vc. The only thing I didn't like is it's not very visually pleasing. Hard to plend in on a deck. But good product. Made it thru a Wisconsin winter with no problem.
Date published: 2013-07-21
Rated 4 out of 5 by from Good outdoor control.This is a hefty outdoor volume control. The volume control board is heavy for it's size. That weight is in the transformers which is a good thing. I thought that it may be difficult, after wiring, to assemble the control, but found that it has enough space for the 16 awg cabling. The formed rubber gasket is adequate to seal the control without adding any other sealers. Overall a good outdoor control.
Date published: 2013-06-27
Rated 4 out of 5 by from Dayton is tried and trueI chose to purchase the Dayton outdoor volume control after having read numerous reviews about other brands available through various websites and stores. Dayton has been around a very long time for a very good reason: they make or represent high quality equipment. Is it a piece an audiophile might select? Probably not, but I'm no audiophile...just a person who loves music and likes things which are well made, sturdy, and smart. This volume control is easily installed, the design permits easy handling (the connections are done through a detachable terminal bus which connects through pin connections - very clever for the installation ease), and the enclosure is well constructed and weatherproofed. Well done. The only complaint is it does "eat" power a bit in pass through of the signal, a minor issue for outdoor equipment where, like most similar installations, we installed soffit-hung 6-1/2" outdoor speakers, not the booming JBL's we have indoors...that loss of power is noticeable, but not insurmountable. Overall, a great choice for the control.
Date published: 2013-06-26
Rated 5 out of 5 by from Good quality construction and partsworks great, good quality, durable, definitely worth the extra money over the cheap ones on amazon
Date published: 2012-05-28
  • 2016-02-14T06:43CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_300-564, PRD, sort_mostRecent
How many pairs of 8ohm speakers can be hooked up to one volume control.  How would you wire three pairs?
Asked by: Woof
These controls are only designed for one pair of 8 ohm speakers.
Date published: 2015-04-13
Power Handling
I have this volume control and I have trouble with it tripping my Marantz receiver from time to time. My receiver is rated at 110wpc and wondering if that has something to do with it.Problem happens mainly when streaming music to my receiver and a song loads that is louder or heavier bass than last and circuit protection trips.What is peak power handling for this control?
Asked by: CarloD
Power handling is likely not the issue here. How many speakers do you have running on this volume control?
Date published: 2013-07-16
Can I see instructions on wiring?
Asked by: sjw1976
Yes, there's a manual linked on the left side-bar of the page.This is very interesting, it's actually a TVC. I'm not a big fan of circuits that get between the amp and the speaker but this one seems to serve some interesting functions, namely impedance matching. I'm a bit concerned about its bandwidth but otherwise it looks fairly interesting.
Answered by: AlonzoTG
Date published: 2011-08-10
  • 2016-02-14T07:57CST
  • loc_en_US, sid_300-564, PRD, sort_recentQuestionsFirst
