Wired Home IRE1 Single IR Emitter with Confirmation LED
Brand:|Model: IRE1|Part # 182-839
Wired Home emitters are an attractive, affordable way to finish your distributed IR system.
List Price$7.99
You Save24%
$6.10
Buy 4-23 $5.80
Buy 24+$4.80
Part # 182-839
  • Elegant design and compact size
  • Built-in confirmation LED
  • Compatible with 12 VDC IR repeater systems
  • Infrared passive, deep-purple shell
The Wired Home IRE1 offers excellent flexibility for distributed IR systems. The deep-purple shell passes infrared so you can use your remote control even with the emitter in place. With a 10 ft. long cable, it's easy to route the IRE1 in, around, and through your AV system to control the necessary device. Utilizing a standard 3.5 mm plug, this IR emitter is compatible with most IR systems. To install, simply peel off the adhesive backing and stick the emitter over your AV device's IR target. You will know that the emitter is repeating a signal when you see the confirmation LED flashing.
Specifications: • Power: 12V DC • Connector: 3.5 mm, 2-conductor (mono) • Color: Deep-purple • Wavelength: 635-640 nm • Cord length: 10 ft. • Dimensions: 15 mm (L) x 10 mm (W) x 6 mm (H)
  • BrandWired Home
  • ModelIRE1
  • Part Number182-839
  • UPC844632099274
  • Product CategoryIR Emitters
  • Weight0.1 lbs.
View similar products to the Wired Home IRE1 Single IR Emitter with Confirmation LED
in the IR Emitters product category.
