181-566_ALT_0
181-566_ALT_1
181-566_ALT_2
181-566_ALT_3
181-566_ALT_4
181-566_ALT_5
181-566_ALT_6
181-566_ALT_7
181-566_ALT_9
Wired Home HR1450 50 ft. High Speed HDMI Cable with Ethernet Supports 3D and Audio Return
Brand:|Model: HR1450
This Wired Home 50 ft. HR1450 HDMI cable is built for the latest HDMI technology, featuring bi-directional Ethernet Channel (HEC), Audio Return Channel (ARC), 3D support, deep color, and resolutions up to 1080p.
This High-Speed HDMI Cable is available in the following lengths:
1 ft.   2 ft.   3 ft.   6 ft.   9 ft.   12 ft.   18 ft.   25 ft.   35 ft.   50 ft.
List Price$57.99
You Save23%
$44.56
Buy 4-24 $42.34
Buy 25+$40.22
Part # 181-566
  • Bi-directional Ethernet Channel (HEC) for internet connection
  • Audio Return Channel (ARC) to feed audio from TV to AV receiver
  • Capable of high-resolution video up to 1080p
  • High transfer rates support 3D and deep color
  • CL2 rated PVC jacket to run behind walls
  • Lifetime warranty
The magic of HDMI is its ability to transmit huge amounts of information through one small cable. Wired Home cables are simply manufactured using processes and materials necessary to guarantee the signal sent through the cable will remain intact and unaltered, resulting in the most enjoyable HDTV viewing experience possible. These cables achieve the capabilities of HDMI Version 1.4, covering all the support you need for modern home entertainment technology.
Reduce your cables and increase your connections.
Now that TVs are able to connect to the Internet, why bother connecting everything else individually? Wired Home HDMI cables offer bi-directional HDMI Ethernet Channel (HEC) that allows you to share the network connection between devices. Use this cable with your gaming console, digital media receiver, Blu-ray player, or DVR to connect to your TV's network connection, along with audio and video transfer.
When using an antenna or a network based application within your TV, the audio source starts at the TV. Instead of running a cable to the receiver for audio, you can now run it through a Wired Home HDMI cable, which is also sending video to the TV. The Audio Return Channel (ARC) functionality in these cables allows you to do this – reducing your cable count and simplifying your home entertainment system.
High speed transfer rates support the latest in HDMI technology.
Due to the impressive construction quality on Wired Home HDMI cables, they are capable of high speed transfer rates. These transfer rates mean that you can get high resolutions up to 1080p, deep color (30/36/48-bit), and supports 3D technology.
High quality cables deserve high quality protection.
Wired Home provides efficient signal transfer by using high quality materials for cable construction. Oxygen free 24 AWG copper conductors are triple shielded with Mylar foil to make sure your signal travels quickly and uninterrupted. Connectors are plated with 24 karat gold to provide excellent conduction. The outside PVC jacket is CL2 rated for proper installation behind walls. The low profile connector and flexible jacket makes routing these cables much easier. Cable is packaged in simple, recyclable, easy to open packaging. Lifetime warranty.
  • Cable TypeHDMI Male to Male
  • Cable Length50 ft.
  • Jacket ColorBlack
  • Wire Gauge24 AWG
  • Special FeaturesCL2 Rated
  • BrandWired Home
  • ModelHR1450
  • Part Number181-566
  • UPC848864007946
  • Product CategoryHDMI Cables
    (4 Reviews)
  • Weight4.1000 lbs.
View similar products to the Wired Home HR1450 50 ft. High Speed HDMI Cable with Ethernet Supports 3D and Audio Return
in the HDMI Cables product category.
Wired Home HR1450 50 ft. High Speed HDMI Cable with Ethernet Supports 3D and Audio Return is rated 4.75 out of 5 by 4.
Rated 5 out of 5 by from good quality cable at an affordable price.good heavy duty wire coating to protect the wire from abrasions, nicks, & cuts. enables me to view my computer on my big screen tv.
Date published: 2015-03-06
Rated 4 out of 5 by from Worked as intended, though bulky.I used the 50ft. length of this HDMI cable to connect my remotely mounted home theater equipment to my TV by running the cable through the walls. This was made difficult by the larger than average plug size as well as the hefty jacket diameter. These features make the cable pretty bullet proof, but harder to manage.I don't use the full features of the cable (such as audio return, 3D, etc.) so I cannot comment as the to the cables handling of such data; however is seems to work just fine as an HDMI monitor cable.Overall, it is well worth the price, so long as you can deal with the bulk of the connectors.
Date published: 2014-10-13
Rated 5 out of 5 by from Best Cable for the MoneyAs I was shopping around for a 50'cable in the other retail stores the Prices were out of this world!! for the money, I would buy this one over and over again!! I did not have any problem fishing this through the wall at all.
Date published: 2014-03-18
Rated 5 out of 5 by from great product50' HDMI cable performs flawless. Cable thickness is a bit cumbersome better for in wall installations then exposed type.
Date published: 2014-02-04
  • 2015-09-01T07:14CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_181-566, PRD, sort_mostRecent
I installed this cable but am getting signal loss. Do I need an extender with this distance?
Asked by: Glenn1234
You may need to use an amplified extender like parts # 181-766
Answered by: TomI
Date published: 2015-06-16
Will this cable be good for 4k tv?
Asked by: creed9
Yes. There is no special cable requirement for 4k TV other than 1.4v HDMI
Answered by: TomI
Date published: 2015-01-28
  • 2015-09-01T08:34CST
  • loc_en_US, sid_181-566, PRD, sort_recentQuestionsFirst
