181-564_ALT_0
181-564_ALT_1
181-564_ALT_2
181-564_ALT_3
181-564_ALT_4
181-564_ALT_5
181-564_ALT_6
181-564_ALT_7
181-564_ALT_9
Wired Home HR1435 35 ft. High Speed HDMI Cable with Ethernet Supports 3D and ARC CL2 Rated
Brand:|Model: HR1435|Part # 181-564
This Wired Home 35 ft. HR1435 HDMI cable is built for the latest HDMI technology, featuring bi-directional Ethernet Channel (HEC), Audio Return Channel (ARC), 3D support, deep color, and resolutions up to 1080p.
This High-Speed HDMI Cable is available in the following lengths:
1 ft.   2 ft.   3 ft.   6 ft.   9 ft.   12 ft.   18 ft.   25 ft.   35 ft.   50 ft.
List Price$41.99
You Save23%
$32.20
Buy 4-24 $30.59
Buy 25+$29.06
Part # 181-564
  • Bi-directional Ethernet Channel (HEC) for internet connection
  • Audio Return Channel (ARC) to feed audio from TV to AV receiver
  • Capable of high-resolution video up to 1080p
  • High transfer rates support 3D and deep color
  • CL2 rated PVC jacket to run behind walls
  • Lifetime warranty
The magic of HDMI is its ability to transmit huge amounts of information through one small cable. Wired Home cables are simply manufactured using processes and materials necessary to guarantee the signal sent through the cable will remain intact and unaltered, resulting in the most enjoyable HDTV viewing experience possible. These cables achieve the capabilities of HDMI Version 1.4, covering all the support you need for modern home entertainment technology.
Reduce your cables and increase your connections.
Now that TVs are able to connect to the internet, why bother connecting everything else individually? Wired Home HDMI cables offer bi-directional HDMI Ethernet Channel (HEC) that allows you to share the network connection between devices. Use this cable with your gaming console, digital media receiver, Blu-ray player, or DVR to connect to your TV's network connection, along with audio and video transfer.
When using an antenna or a network based application within your TV, the audio source starts at the TV. Instead of running a cable to the receiver for audio, you can now run it through a Wired Home HDMI cable, which is also sending video to the TV. The Audio Return Channel (ARC) functionality in these cables allows you to do this – reducing your cable count and simplifying your home entertainment system.
High speed transfer rates support the latest in HDMI technology.
Due to the impressive construction quality on Wired Home HDMI cables, they are capable of high speed transfer rates. These transfer rates mean that you can get high resolutions up to 1080p, deep color (30/36/48-bit), and supports 3D technology.
High quality cables deserve high quality protection.
Wired Home provides efficient signal transfer by using high quality materials for cable construction. Oxygen free 24 AWG copper conductors are triple shielded with Mylar foil to make sure your signal travels quickly and uninterrupted. Connectors are plated with 24 karat gold to provide excellent conduction. The outside PVC jacket is CL2 rated for proper installation behind walls. The low profile connector and flexible jacket makes routing these cables much easier. Cable is packaged in simple, recyclable, easy to open packaging. Lifetime warranty.
  • Cable TypeHDMI Male to Male
  • Cable Length35 ft.
  • Jacket ColorBlack
  • Wire Gauge24 AWG
  • Special FeaturesCL2 Rated
  • BrandWired Home
  • ModelHR1435
  • Part Number181-564
  • UPC848864007939
  • Product CategoryHDMI Cables
    (9 Reviews)
  • Weight2.9500 lbs.
View similar products to the Wired Home HR1435 35 ft. High Speed HDMI Cable with Ethernet Supports 3D and ARC CL2 Rated
in the HDMI Cables product category.
Wired Home HR1435 35 ft. High Speed HDMI Cable with Ethernet Supports 3D and ARC CL2 Rated is rated 4.4444 out of 5 by 9.
Rated 3 out of 5 by from Reasonably priced. VERY THICK/STIFFFirst and foremost i received everything super fast as always!! So i mounted all my components in a closet so they were outta sight outta mind. I also used a Wired Home IR repeater kit model: DBIRX to send the signal to the closet. I ran 2" pvc from behind the TV to the closet so I didnt have to route the cables til after I finished the basement. The HDMI cables were very heavy and stiff. I have flexibility where the cables come into the A/V closet but to plug the other end directly into the TV was a task to say the least. Might have to get a dual HDMI wall plate and used more flexible 3' cables to connect to TV. Other than the stiffness which is why I gave it 3 stars, I was happy with my purchase and will continue to purchase from Parts Express!!
Date published: 2015-08-10
Rated 5 out of 5 by from Ever think you would need a 35 foot cord?If you want to hide the cord behind a wall and make a positive impact from your source to a tv. This is for you.
Date published: 2015-06-04
Rated 5 out of 5 by from Well madeCable has good construction and solid connectors.Heavy.
Date published: 2015-05-08
Rated 5 out of 5 by from Great cableWhat can you say about a cable... Works as expected. Good quality construction. I needed this to pull through a conduit that is 25 feet long. The jacket on this cable glided smoothly through the conduit needing much less effort then other cables I've used.
Date published: 2015-04-16
Rated 5 out of 5 by from great price excellent quality.bought this cable for my fathers new flat screen tv. arrived very quickly. surprised by the quality of cable for the price. great product. love parts express
Date published: 2015-03-05
Rated 5 out of 5 by from Worked great for my need!Looking for this particular length for a projector install and I'm very happy with the cable. Sync'ed up fine between items. Jacket was an easy install through drop ceiling. Thanks Parts Express!
Date published: 2015-01-26
  • 2016-02-08T06:42CST
  • co_hasreviews, tv_0, tr_9
  • loc_en_US, sid_181-564, PRD, sort_mostRecent
My laptop [HP] does not have a HDMI port. It has 4 ports that a flash drive fits. I want to stream movies from NETFLIX to a VIZIO FLAT SCREEN, which has 2 HDMI ports. How would I proceed?
Asked by: RB 25
It sounds like you are referring to USB ports on your computer. you will need a USB to HDMI adapter sold by others.
Answered by: TomI
Date published: 2015-01-27
How large of a hole does it need to fit through a wall? Also, I have to go outside and then back into the house. Will the wire it's self hold up ok in the weather? Thanks RDB
Asked by: Rivetman1
Measuring the widest part of the connector diagonally, it is ~7/8". I would recommend a hole that is no smaller than 1" for this cable.
Date published: 2014-12-17
can we use this cable to hook up a antroid box ?
Asked by: clarn
This cable will work with any device with HDMI input/output.
Answered by: PE Tom
Date published: 2014-06-12
  • 2016-02-08T07:15CST
  • loc_en_US, sid_181-564, PRD, sort_recentQuestionsFirst
