181-558_ALT_0
181-558_ALT_1
181-558_ALT_2
181-558_ALT_3
181-558_ALT_4
181-558_ALT_5
181-558_ALT_6
181-558_ALT_7
181-558_ALT_9
Wired Home HR1412 12 ft. High Speed HDMI Cable with Ethernet Supports 3D and Audio Return
Brand:|Model: HR1412
This Wired Home 12 ft. HR1412 HDMI cable is built for the latest HDMI technology, featuring bi-directional Ethernet Channel (HEC), Audio Return Channel (ARC), 3D support, deep color, and resolutions up to 1080p.
This High-Speed HDMI Cable is available in the following lengths:
1 ft.   2 ft.   3 ft.   6 ft.   9 ft.   12 ft.   18 ft.   25 ft.   35 ft.   50 ft.
List Price$8.99
You Save31%
$6.20
Buy 4-24 $5.89
Buy 25+$5.60
Part # 181-558
  • Bi-directional Ethernet Channel (HEC) for internet connection
  • Audio Return Channel (ARC) to feed audio from TV to AV receiver
  • Capable of high-resolution video up to 1080p
  • High transfer rates support 3D and deep color
  • CL2 rated PVC jacket to run behind walls
  • Lifetime warranty
The magic of HDMI is its ability to transmit huge amounts of information through one small cable. Wired Home cables are simply manufactured using processes and materials necessary to guarantee the signal sent through the cable will remain intact and unaltered, resulting in the most enjoyable HDTV viewing experience possible. These cables achieve the capabilities of HDMI Version 1.4, covering all the support you need for modern home entertainment technology.
Reduce your cables and increase your connections.
Now that TVs are able to connect to the Internet, why bother connecting everything else individually? Wired Home HDMI cables offer bi-directional HDMI Ethernet Channel (HEC) that allows you to share the network connection between devices. Use this cable with your gaming console, digital media receiver, Blu-ray player, or DVR to connect to your TV's network connection, along with audio and video transfer.
When using an antenna or a network based application within your TV, the audio source starts at the TV. Instead of running a cable to the receiver for audio, you can now run it through a Wired Home HDMI cable, which is also sending video to the TV. The Audio Return Channel (ARC) functionality in these cables allows you to do this – reducing your cable count and simplifying your home entertainment system.
High speed transfer rates support the latest in HDMI technology.
Due to the impressive construction quality on Wired Home HDMI cables, they are capable of high speed transfer rates. These transfer rates mean that you can get high resolutions up to 1080p, deep color (30/36/48-bit), and supports 3D technology.
High quality cables deserve high quality protection.
Wired Home provides efficient signal transfer by using high quality materials for cable construction. Oxygen free 28 AWG copper conductors are triple shielded with Mylar foil to make sure your signal travels quickly and uninterrupted. Connectors are plated with 24 karat gold to provide excellent conduction. The outside PVC jacket is CL2 rated for proper installation behind walls. The low profile connector and flexible jacket makes routing these cables much easier. Cable is packaged in simple, recyclable, easy to open packaging. Lifetime warranty.
  • Cable TypeHDMI Male to Male
  • Cable Length12 ft.
  • Jacket ColorBlack
  • Wire Gauge28 AWG
  • Special FeaturesCL2 Rated
  • BrandWired Home
  • ModelHR1412
  • Part Number181-558
  • UPC848864007908
  • Product CategoryHDMI Cables
    (2 Reviews)
  • Weight0.579 lbs.
View similar products to the Wired Home HR1412 12 ft. High Speed HDMI Cable with Ethernet Supports 3D and Audio Return
in the HDMI Cables product category.
Wired Home HR1412 12 ft. High Speed HDMI Cable with Ethernet Supports 3D and Audio Return is rated 5.0 out of 5 by 2.
Rated 5 out of 5 by from Great value cablesI needed longer HDMI cables for a new in-wall installation. These cables were the right length and the right price! Probably $60 cheaper than at B**t B*y. Fast shipping, too. Save your money by skipping the fancy packages and marketing hype.
Date published: 2014-10-30
Rated 5 out of 5 by from Great valueWith so many products on the market it is hard to choose the right one.this cord does the job at the right price. I recommend it.
Date published: 2014-05-20
  • 2015-08-31T07:14CST
  • co_hasreviews, tv_0, tr_2
  • loc_en_US, sid_181-558, PRD, sort_mostRecent
