181-556_ALT_0
181-556_ALT_1
181-556_ALT_2
181-556_ALT_3
181-556_ALT_4
181-556_ALT_5
181-556_ALT_6
181-556_ALT_7
181-556_ALT_9
181-556_ALT_10
Wired Home HR1406 6 ft. High Speed HDMI Cable with Ethernet Supports 3D and ARC CL2 Rated
Brand:|Model: HR1406|Part # 181-556
This Wired Home 6 ft. HR1406 HDMI cable is built for the latest HDMI technology, featuring bi-directional Ethernet Channel (HEC), Audio Return Channel (ARC), 3D support, deep color, and resolutions up to 1080p.
This High-Speed HDMI Cable is available in the following lengths:
1 ft.   2 ft.   3 ft.   6 ft.   9 ft.   12 ft.   18 ft.   25 ft.   35 ft.   50 ft.
List Price$5.99
You Save34%
$3.98
Buy 4-24 $3.84
Buy 25+$3.70
Part # 181-556
  • Bi-directional Ethernet Channel (HEC) for internet connection
  • Audio Return Channel (ARC) to feed audio from TV to AV receiver
  • Capable of high-resolution video up to 1080p
  • High transfer rates support 3D and deep color
  • CL2 rated PVC jacket to run behind walls
  • Lifetime warranty
The magic of HDMI is its ability to transmit huge amounts of information through one small cable. Wired Home cables are simply manufactured using processes and materials necessary to guarantee the signal sent through the cable will remain intact and unaltered, resulting in the most enjoyable HDTV viewing experience possible. These cables achieve the capabilities of HDMI Version 1.4, covering all the support you need for modern home entertainment technology.
Reduce your cables and increase your connections.
Now that TVs are able to connect to the Internet, why bother connecting everything else individually? Wired Home HDMI cables offer bi-directional HDMI Ethernet Channel (HEC) that allows you to share the network connection between devices. Use this cable with your gaming console, digital media receiver, Blu-ray player, or DVR to connect to your TV's network connection, along with audio and video transfer.
When using an antenna or a network based application within your TV, the audio source starts at the TV. Instead of running a cable to the receiver for audio, you can now run it through a Wired Home HDMI cable, which is also sending video to the TV. The Audio Return Channel (ARC) functionality in these cables allows you to do this – reducing your cable count and simplifying your home entertainment system.
High speed transfer rates support the latest in HDMI technology.
Due to the impressive construction quality on Wired Home HDMI cables, they are capable of high speed transfer rates. These transfer rates mean that you can get high resolutions up to 1080p, deep color (30/36/48-bit), and supports 3D technology.
High quality cables deserve high quality protection.
Wired Home provides efficient signal transfer by using high quality materials for cable construction. Oxygen free 28 AWG copper conductors are triple shielded with Mylar foil to make sure your signal travels quickly and uninterrupted. Connectors are plated with 24 karat gold to provide excellent conduction. The outside PVC jacket is CL2 rated for proper installation behind walls. The low profile connector and flexible jacket makes routing these cables much easier. Cable is packaged in simple, recyclable, easy to open packaging. Lifetime warranty.
  • Cable TypeHDMI Male to Male
  • Cable Length6 ft.
  • Jacket ColorBlack
  • Wire Gauge28 AWG
  • Special FeaturesCL2 Rated
  • BrandWired Home
  • ModelHR1406
  • Part Number181-556
  • UPC848864007892
  • Product CategoryHDMI Cables
    (6 Reviews)
  • Weight0.349 lbs.
View similar products to the Wired Home HR1406 6 ft. High Speed HDMI Cable with Ethernet Supports 3D and ARC CL2 Rated
in the HDMI Cables product category.
Wired Home HR1406 6 ft. High Speed HDMI Cable with Ethernet Supports 3D and ARC CL2 Rated is rated 5.0 out of 5 by 6.
Rated 5 out of 5 by from Excellent product, excellent price.I have always been satisfied with Parts Express purchases. This cable works perfectly and was a great deal.
Date published: 2015-01-12
Rated 5 out of 5 by from Wired Home HR1406 6 ft. High Speed HDMI Cable withPE is the only place to buy HDMI cables. They are very good cables and you can't bet the price.
Date published: 2014-07-31
Rated 5 out of 5 by from Great cableVery affordable and useful cable, does what it's supposed to do. Good service from Parts Express
Date published: 2014-07-12
Rated 5 out of 5 by from Low Price, Great Buy!Purchased these last month, Works great. Compared to the prices at local electronic stores this was a steal. So far no problems. Even with standard free delivery it only took a week.
Date published: 2014-03-14
Rated 5 out of 5 by from Excellent valueI have used these HDMI cables before and they offer great performance and value
Date published: 2014-02-13
Rated 5 out of 5 by from Work greatThese cables work as stated in the description and are ALOT less expensive than at the local stores. Very flexible and well constructed.
Date published: 2014-01-30
  • 2016-02-07T06:53CST
  • co_hasreviews, tv_0, tr_6
  • loc_en_US, sid_181-556, PRD, sort_mostRecent
Does this work for a Samsung 4K TV?
Asked by: BettyFG
Yes, this will work well.
Answered by: MattW
Date published: 2015-11-17
What is the transfer speedrate for the HR1 406 6FT. HDMI Cable with Ethernet?  Has the cable been injected with nitrogen gas?
Asked by: Hombre
All of our cables are ATC certified and support the throughput of 10.2 Gbit/s as required by a High Speed HDMI Cable.With regard to nitrogen gas; nitrogen injection is normally used when manufacturing the dielectric of a coax cable. The dielectric in a coax cable allows the cable to maintain its shape, and the correct spacing between the center conductor and shield to maintain the designed impedance. Since the optimum dielectric for a coax cable is air, cable manufacturers use nitrogen injected foam dielectric because it provides the closest properties to air.Nitrogen Injection does not apply since there is no dielectric used in an HDMI cable.Before you purchase your HDMI cables, please read our primer; "Understanding HDMI Cables" at this link: http://www.parts-express.com/resources-understanding-hdmi-cables
Answered by: PE Tom
Date published: 2014-05-06
  • 2016-02-07T07:26CST
  • loc_en_US, sid_181-556, PRD, sort_recentQuestionsFirst
