CLEARANCE
Wired Home HF13C210 33 ft. High-Speed Flat HDMI Cable
Brand:|Model: HF13C210|Part # 181-796
Wired Home's flat, high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. The flat design reduces the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b.
Which length will work best for you?
1.65 ft. Dayton Audio High-Speed Flat HDMI Cable3.3 ft. Dayton Audio High-Speed Flat HDMI Cable6.6 ft. Dayton Audio High-Speed Flat HDMI Cable9.9 ft. Dayton Audio High-Speed Flat HDMI Cable16.5 ft. Dayton Audio High-Speed Flat HDMI Cable23.1 ft. Dayton Audio High-Speed Flat HDMI Cable33 ft. Dayton Audio High-Speed Flat HDMI Cable
List Price$34.99
Regular Price$23.15
You Save47%
Sale Price
$12.33
Part # 181-796
  • Supports resolutions up to 1600p, refresh rates up to 240 Hz, and 48-bit Deep Color
  • Flat cable construction reduces cable footprint while reducing cross-talk
  • HDCP compliant for protected content playback such as Blu-ray
  • ATC certified HDMI v1.3b Category 2
Wired Home's high-speed HDMI cables present the purest, most pristine digital high-definition audio and video signals to your HDTV and HDMI-enabled equipment. Unleash the full potential of high definition 1080p video and lossless Dolby® TrueHD or DTS-HD Master Audio™ audio formats. Shielded, 28AWG twisted-pair oxygen-free conductors make this cable ideal for permanent installations. All connector contact surfaces are plated with 24 karat gold to provide a lifetime of reliable service. The flat design of these HDMI cables further separates the cable pairs reducing the effects of inter-pair cross-talk. ATC certification guarantees HDMI v1.3b compliance, as well as faster 340 MHz (10.2 Gbps) performance. Support for 240 Hz refresh rates, Lip Sync audio/video synchronization and future-proofing for monitors able to display up to a 1600p resolution is built-in.
No Questions Asked Lifetime Warranty
  • Cable TypeHDMI Male to Male
  • Cable Length33 ft.
  • Jacket ColorBlack
  • Wire Gauge28 AWG
  • Special FeaturesCL2 Rated,Flat
  • BrandWired Home
  • ModelHF13C210
  • Part Number181-796
  • UPC844632071072
  • Product CategoryHDMI Cables
    (8 Reviews)
  • Weight1.5000 lbs.
View similar products to the Wired Home HF13C210 33 ft. High-Speed Flat HDMI Cable
in the HDMI Cables product category.
Wired Home HF13C210 33 ft. High-Speed Flat HDMI Cable is rated 4.5 out of 5 by 8.
Rated 5 out of 5 by from Well constructedBought this cable to use with the Mini 1 x 2 HDMI Splitter. It has a thick rubber like covering and nicely molded connector covers. The HDMI video is great; I am not passing audio in my application.
Date published: 2015-01-03
Rated 5 out of 5 by from Great product great imageGot this cable for my home theater and it is perfect to hide it in tight spaces along the baseboard
Date published: 2014-07-10
Rated 5 out of 5 by from as advertisedworked fine right out of the wrapper, good connectors,good contact
Date published: 2014-03-05
Rated 1 out of 5 by from Very bad experience with this cable turns costlyBefore drilling holes in my walls and mounting wall plates from one room to the next, I decided I had better try this cable out. So I plugged one end into my very expensive and relatively new Marantz AV7005. I then ran the cable around the corner, down the hall and into my bedroom to the Panasonic 42" plasma on the wall. When I went to plug the cable into my TV, it sparked and ended up blowing all the HDMI inputs - taking out the control board and HDMI processor. Repairs? $360! (Too much to warrant, since I only paid $600 for the TV). If that wasn't bad enough, it also took out the three HDMI outputs on the AV7005 pre-amp! Fortunately, that was still under warranty. Would I recommend this to anyone? Duh, NO!When the TV repair place asked me if I tried the cable in anything else - I said "NO WAY! I can't afford to burn up any more equipment!"
Date published: 2011-12-01
Rated 5 out of 5 by from Dayton Audio HF13C210 33 ft. High-Speed Flat HDMI CablePerformance as advertised - great cable at a great price - link HD Laptop to HD TV for home entertainment center.
Date published: 2011-10-23
Rated 5 out of 5 by from Solid ProductWe use these cables daily. Excellent value and the flexibility of the flat profile make them the best value in HDMI in the marketplace. 10.2 Gbps in a 10 Meter HDMI cable at this price is huge.
Date published: 2009-10-24
  • 2016-02-07T07:07CST
  • co_hasreviews, tv_0, tr_8
  • loc_en_US, sid_181-796, PRD, sort_mostRecent
