Wired Home 52164H9Y 16/4 In Wall Speaker Wire Cable CL2 500 ft.
Brand:|Model: 52164H9Y|Part # 101-235
Wired Home's in-wall speaker cable incorporates only the purest, high-quality copper. Each size and style of Wired Home cable includes materials and construction that guarantee cost-effective yet exceptionally solid audio performance.
OUT OF STOCK
Due In: 2/12/2016
List Price$289.99
You Save46%
$156.04
Buy 4+$143.46
Part # 101-235
  • UL listed and CL2-rated for in-wall installations
  • Flexible enough to use as speaker cables outside of walls
  • High-purity 99.996% oxygen-free copper conductors maximize conductivity
  • Low DC resistance and capacitance—even over long runs
  • Sequential foot markers indicate cable remaining in the box
  • Pulls and strips easily, reducing installation time
There's no reason to install performance-degrading inferior speaker cable in your home theater or whole-house audio system. Low cost, fully optimized Wired Home audiophile grade speaker cable is the better option! Wired Home's fine copper wire strands minimize capacitance that causes low frequency losses, and each insulated conductor is twisted tightly in pairs to reduce high frequency attenuation caused by excessive inductance.
This tight twist also results in a rounder cable profile, making the product much easier to pull around sharp-cornered studs or through conduit. Wired Home in-wall cable features a smooth, easy to feed, tube-style outer jacket for easy installation and wire preparation. UL listed, RoHS compliant, and CL2-rated (temperature rated to 75° C).
Specifications: • Individual conductor: 65 x 34 AWG • Individual conductor overall diameter: 2.1 mm • Overall cable diameter: 6.80 mm • DCR: 1.40 ohms/100 meters.
  • Cable Rating UL Listed,CM Rated,CL2 Rated
  • Wire Gauge16 AWG
  • # of Conductors4 Conductor
  • Jacket ColorWhite
  • Length500 ft.
  • BrandWired Home
  • Model52164H9Y
  • Part Number101-235
  • UPC844632071508
  • Product CategoryIn-Wall Speaker Wire
    (3 Reviews)
  • Weight33.75 lbs.
View similar products to the Wired Home 52164H9Y 16/4 In Wall Speaker Wire Cable CL2 500 ft.
in the In-Wall Speaker Wire product category.
Wired Home 52164H9Y 16/4 In Wall Speaker Wire Cable CL2 500 ft. is rated 4.0 out of 5 by 3.
Rated 5 out of 5 by from Dayton 4-conductorGreat cable. Easy to remove plenum and very flexible.
Date published: 2013-08-26
Rated 3 out of 5 by from Not as good as it used to beDayton has changed two things about this wire since I wrote my last review in '09, both for the worse. One, the jacket is not uniformly round as it was, so the appearance of the wire is not attractive. Two, the packaging of the wire is extremely flimsy, so forget about the "auto feed" feature.That said, it is still a good quality, true 16ga wire, high strand count, flexible, easy to work with. I will still buy this for my house wiring jobs, but will now start looking for something better.
Date published: 2012-02-29
Rated 4 out of 5 by from Best value architectural wireYou're not going to find a better quality 16-4 architectural speaker wire in this price range! Great quality wire, true 16 gauge, very fine strands, nice and flexible. Just a couple of minor quibbles. One, the jacket only marked every other foot, the odd numbers are not marked. Two, the box is a little flimsy so you might want to reinforce with packing tape before you try to feed the wire.
Date published: 2009-11-11
  • 2016-02-07T07:11CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_101-235, PRD, sort_mostRecent
