101-233_ALT_0
Wired Home 52164H9E 16/4 In Wall Speaker Wire Cable CL2 250 ft.
Brand:|Model: 52164H9E|Part # 101-233
Wired Home's in-wall speaker cable incorporates only the purest, high-quality copper. Each size and style of Wired Home cable includes materials and construction that guarantee cost-effective yet exceptionally solid audio performance.
List Price$149.99
You Save48%
$77.86
Buy 4+$71.58
Part # 101-233
  • UL listed and CL2-rated for in-wall installations
  • Flexible enough to use as speaker cables outside of walls
  • High-purity 99.996% oxygen-free copper conductors maximize conductivity
  • Low DC resistance and capacitance—even over long runs
  • Sequential foot markers indicate cable remaining on the spool
  • Pulls and strips easily, reducing installation time
There's no reason to install performance-degrading inferior speaker cable in your home theater or whole-house audio system. Low cost, fully optimized Wired Home audiophile grade speaker cable is the better option! Wired Home's fine copper wire strands minimize capacitance that causes low frequency losses, and each insulated conductor is twisted tightly in pairs to reduce high frequency attenuation caused by excessive inductance.
This tight twist also results in a rounder cable profile, making the product much easier to pull around sharp-cornered studs or through conduit. Wired Home in-wall cable features a smooth, easy to feed, tube-style outer jacket for easy installation and wire preparation. UL listed, RoHS compliant, and CL2-rated (temperature rated to 75° C).
Specifications: • Individual conductor: 65 x 34 AWG • Individual conductor overall diameter: 2.1 mm • Overall cable diameter: 6.80 mm • DCR: 1.40 ohms/100 meters • Cable dispensed from a plastic spool.
  • Cable Rating UL Listed,CM Rated,CL2 Rated
  • Wire Gauge16 AWG
  • # of Conductors4 Conductor
  • Jacket ColorWhite
  • Length250 ft.
  • BrandWired Home
  • Model52164H9E
  • Part Number101-233
  • UPC844632071492
  • Product CategoryIn-Wall Speaker Wire
    (3 Reviews)
  • Weight15.85 lbs.
View similar products to the Wired Home 52164H9E 16/4 In Wall Speaker Wire Cable CL2 250 ft.
in the In-Wall Speaker Wire product category.
Wired Home 52164H9E 16/4 In Wall Speaker Wire Cable CL2 250 ft. is rated 4.3333 out of 5 by 3.
Rated 5 out of 5 by from ExcellentLowest cost 4 conductor I found on the internet, other places were literally twice as much from mouser and digikey. Very flexible, ran through some very tight areas and it pulled just fine. Sheathing is good quality.
Date published: 2012-11-01
Rated 4 out of 5 by from Great qualityThe wire was very nice to work with. It's sheathing worked well when pulling wires through a new construction project. I would recommend this to other. Great value for the money.
Date published: 2012-06-01
Rated 4 out of 5 by from Great Wire / Plastic spool not so good.The wire is excellent, very good quality for the price. However, the plastic cable spool is not so good. I've been using this product for years now, and my only complaint is that the plastic spools break way too easily. Most of the time, they arrive already damaged. (Maybe during shipping, i don't know). It is true that the wire is really what I need, and not the spool. But a broken spool makes it very difficult to pull wires during installations.I will continue to buy this product until I can find an alternative.
Date published: 2012-04-17
  • 2016-02-11T06:56CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_101-233, PRD, sort_mostRecent
