101-227_ALT_0
Wired Home 52162H9Y 16/2 In Wall Speaker Wire Cable CL2 500 ft.
Brand:|Model: 52162H9Y|Part # 101-227
Wired Home's in-wall speaker cable incorporates only the purest, high-quality copper. Each size and style of Wired Home cable includes materials and construction that guarantee cost-effective yet exceptionally solid audio performance.
List Price$154.99
You Save47%
$82.52
Buy 4+$75.87
Part # 101-227
  • UL listed and CL2-rated for in-wall installations
  • Flexible enough to use as speaker cables outside of walls
  • High-purity 99.996% oxygen-free copper conductors maximize conductivity
  • Low DC resistance and capacitance—even over long runs
  • Sequential foot markers indicate cable remaining in the box
  • Pulls and strips easily, reducing installation time
There's no reason to install performance-degrading inferior speaker cable in your home theater or whole-house audio system. Low cost, fully optimized Wired Home audiophile grade speaker cable is the better option! Wired Home's fine copper wire strands minimize capacitance that causes low frequency losses, and each insulated conductor is twisted tightly in pairs to reduce high frequency attenuation caused by excessive inductance.
This tight twist also results in a rounder cable profile, making the product much easier to pull around sharp-cornered studs or through conduit. Wired Home in-wall cable features a smooth, easy to feed, tube-style outer jacket for easy installation and wire preparation. UL listed, RoHS compliant, and CL2-rated (temperature rated to 75° C).
Specifications: • Individual conductor: 65 x 34 AWG • Individual conductor overall diameter: 2.1 mm • Overall cable diameter: 6.0 mm • DCR: 1.40 ohms/100 meters.
  • Cable Rating UL Listed,CM Rated,CL2 Rated
  • Wire Gauge16 AWG
  • # of Conductors2 Conductor
  • Jacket ColorWhite
  • Length500 ft.
  • BrandWired Home
  • Model52162H9Y
  • Part Number101-227
  • UPC844632071461
  • Product CategoryIn-Wall Speaker Wire
    (3 Reviews)
  • Weight23.9 lbs.
View similar products to the Wired Home 52162H9Y 16/2 In Wall Speaker Wire Cable CL2 500 ft.
in the In-Wall Speaker Wire product category.
Wired Home 52162H9Y 16/2 In Wall Speaker Wire Cable CL2 500 ft. is rated 4.3333 out of 5 by 3.
Rated 5 out of 5 by from Great price for in-wall / ceiling speaker wireMany of the other cables out there at amazon and elsewhere claim to be CL2 but some are not actually labeled as such. This was labeled properly and was a good price. No problems at all from me.
Date published: 2014-10-28
Rated 3 out of 5 by from OK, but Spool Breaks EasilyI got a 500' roll that came damaged in shipment and refused delivery. PE was super responsive and got me another one right away, in time for the install. SEcond one was OK, but spool broke inside box about 2/3-way thru the job -- no reason I can see. Had to use broom stick handle straddled by ladder to finish.
Date published: 2014-03-11
Rated 5 out of 5 by from No Jacket stripping issuesIt looks like the last review was written one year ago. I almost did not order the wire because complaints about jacket stripping but took the chance anyway. It looks like in the last year Dayton has fixed the issue, the wire is no longer molded into the jacket and I found it very easy to run and strip. The wire and packaging were both of decent quality, the spool worked very well through the entire 500'. I would buy again.
Date published: 2012-07-30
  • 2016-02-10T07:07CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_101-227, PRD, sort_mostRecent
