101-225_ALT_0
Wired Home 52162H9E 16/2 In Wall Speaker Wire Cable CL2 250 ft.
Brand:|Model: 52162H9E|Part # 101-225
Wired Home's in-wall speaker cable incorporates only the purest, high-quality copper. Each size and style of Wired Home cable includes materials and construction that guarantee cost-effective yet exceptionally solid audio performance.
OUT OF STOCK
Due In: 2/12/2016
List Price$81.99
You Save42%
$47.64
Buy 4+$43.31
Part # 101-225
  • UL listed and CL2-rated for in-wall installations
  • Flexible enough to use as speaker cables outside of walls
  • High-purity 99.996% oxygen-free copper conductors maximize conductivity
  • Low DC resistance and capacitance—even over long runs
  • Sequential foot markers indicate cable remaining on the spool
  • Pulls and strips easily, reducing installation time
There's no reason to install performance-degrading inferior speaker cable in your home theater or whole-house audio system. Low cost, fully optimized Wired Home audiophile grade speaker cable is the better option! Wired Home's fine copper wire strands minimize capacitance that causes low frequency losses, and each insulated conductor is twisted tightly in pairs to reduce high frequency attenuation caused by excessive inductance.
This tight twist also results in a rounder cable profile, making the product much easier to pull around sharp-cornered studs or through conduit. Wired Home in-wall cable features a smooth, easy to feed, tube-style outer jacket for easy installation and wire preparation. UL listed, RoHS compliant, and CL2-rated (temperature rated to 75° C).
Specifications: • Individual conductor: 65 x 34 AWG • Individual conductor overall diameter: 2.1 mm • Overall cable diameter: 6.0 mm • DCR: 1.40 ohms/100 meters • Cable dispensed from a plastic spool.
  • Cable Rating UL Listed,CM Rated,CL2 Rated
  • Wire Gauge16 AWG
  • # of Conductors2 Conductor
  • Jacket ColorWhite
  • Length250 ft.
  • BrandWired Home
  • Model52162H9E
  • Part Number101-225
  • UPC844632071454
  • Product CategoryIn-Wall Speaker Wire
    (3 Reviews)
  • Weight11 lbs.
View similar products to the Wired Home 52162H9E 16/2 In Wall Speaker Wire Cable CL2 250 ft.
in the In-Wall Speaker Wire product category.
Wired Home 52162H9E 16/2 In Wall Speaker Wire Cable CL2 250 ft. is rated 5.0 out of 5 by 3.
Rated 5 out of 5 by from Excellent WireI bought this wire for a pa system. I used it for making zones to turn on and offspeakers in 4 different areas.The speaker system works on 70v and grd. Thewire works great and is easy to run.
Date published: 2014-08-06
Rated 5 out of 5 by from Great valueI used this in a new construction install and it was very easy to pull the wire through the drilled holes. The sheathing protected the wires and makes it easy to work with. I would recommend this to people. Buy it.
Date published: 2012-06-01
Rated 5 out of 5 by from Best speaker wire for the priceThis is a good speaker wire. Very durable and heavy. Which is great when doing wall drops through a attic to a opening down below. The spool was cracked when I received it so it was a little hard to use on my wire spool holder.
Date published: 2009-07-17
  • 2016-02-07T07:11CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_101-225, PRD, sort_mostRecent
