101-223_ALT_0
Wired Home 52162H9A 16/2 In Wall Speaker Wire Cable CL2 100 ft.
Brand:|Model: 52162H9A|Part # 101-223
Wired Home's in-wall speaker cable incorporates only the purest, high-quality copper. Each size and style of Wired Home cable includes materials and construction that guarantee cost-effective yet exceptionally solid audio performance.
OUT OF STOCK
Due In: 2/12/2016
List Price$36.99
You Save51%
$18.00
Buy 4+$16.36
Part # 101-223
  • UL listed and CL2-rated for in-wall installations
  • Flexible enough to use as speaker cables outside of walls
  • High-purity 99.996% oxygen-free copper conductors maximize conductivity
  • Low DC resistance and capacitance—even over long runs
  • Sequential foot markers indicate cable remaining on the spool
  • Pulls and strips easily, reducing installation time
There's no reason to install performance-degrading inferior speaker cable in your home theater or whole-house audio system. Low cost, fully optimized Wired Home audiophile grade speaker cable is the better option! Wired Home's fine copper wire strands minimize capacitance that causes low frequency losses, and each insulated conductor is twisted tightly in pairs to reduce high frequency attenuation caused by excessive inductance.
This tight twist also results in a rounder cable profile, making the product much easier to pull around sharp-cornered studs or through conduit. Wired Home in-wall cable features a smooth, easy to feed, tube-style outer jacket for easy installation and wire preparation. UL listed, RoHS compliant, and CL2-rated (temperature rated to 75° C).
Specifications: • Individual conductor: 65 x 34 AWG • Individual conductor overall diameter: 2.1 mm • Overall cable diameter: 6.0 mm • DCR: 1.40 ohms/100 meters • Cable dispensed from a plastic spool.
  • Cable Rating UL Listed,CM Rated,CL2 Rated
  • Wire Gauge16 AWG
  • # of Conductors2 Conductor
  • Jacket ColorWhite
  • Length100 ft.
  • BrandWired Home
  • Model52162H9A
  • Part Number101-223
  • UPC844632071447
  • Product CategoryIn-Wall Speaker Wire
    (5 Reviews)
  • Weight4.35 lbs.
View similar products to the Wired Home 52162H9A 16/2 In Wall Speaker Wire Cable CL2 100 ft.
in the In-Wall Speaker Wire product category.
Wired Home 52162H9A 16/2 In Wall Speaker Wire Cable CL2 100 ft. is rated 4.8 out of 5 by 5.
Rated 4 out of 5 by from Very easy to work withI used this to fish up one wall, across and attic and back down another wall. Had no issues and it never snagged. It is pretty pliable so coming off the spool it doesn't hold the curl as much as some in-wall speaker wire I've used, which is good. The outer sleeve was easy to cut and wires were easy to strip.
Date published: 2013-10-30
Rated 5 out of 5 by from Great stuff, great value!Bought it for a residential install. Easy to work with, no problems!
Date published: 2013-10-08
Rated 5 out of 5 by from Speaker cable for the massesI bought this cable since the cable I wanted was out of stock, and I'm impatient. I did not need the in wall rated cable, but that's ok. The jacket is pliable and would be a breeze to get through the wall, but also the quality of the wire itself is great, and the sound quality is fantastic (just make sure you get the correct size). I have done much testing on speaker wires and components, and there is no audible difference between a $5 cable and a $5000 cable. People that say they hear a difference with their $5k cables probably do hear a difference, the problem being the difference is in their head and not actually real. Look into blind studies to read more on this, but as far as the cables go, these are great sounding OFC wire, and sound great.
Date published: 2013-05-02
Rated 5 out of 5 by from Very good wireIt was easy to fish up the walls
Date published: 2010-09-23
Rated 5 out of 5 by from Why spend anymore?Great wire for in-wall installs. Great value. Parts Express is wonderful.
Date published: 2009-05-27
  • 2016-02-08T06:46CST
  • co_hasreviews, tv_0, tr_5
  • loc_en_US, sid_101-223, PRD, sort_mostRecent
Will this cable fit into this RCA connector (092-112)?  I need to make a patch cable to run from my soundbar sub-out to my active subwoofer.
Asked by: chitodb
Technically the cable will fit, but you do not want to use speaker wire for this application. I would recommed something that is shielded, like the cable below.http://www.parts-express.com/talent-gi100-22-awg-guitar-and-instrument-cable-100-ft--101-301
Date published: 2014-11-19
  • 2016-02-07T07:28CST
  • loc_en_US, sid_101-223, PRD, sort_recentQuestionsFirst
