Wired Home 52142H9A 14/2 In Wall Speaker Wire Cable CL2 100 ft.
Brand:|Model: 52142H9A|Part # 101-207
Wired Home's in-wall speaker cable incorporates only the purest, high-quality copper. Each size and style of Wired Home cable includes materials and construction that guarantee cost-effective yet exceptionally solid audio performance.
List Price$51.99
You Save55%
$23.50
Buy 4+$21.50
Part # 101-207
  • UL listed and CL2-rated for in-wall installations
  • Flexible enough to use as speaker cables outside of walls
  • High-purity 99.996% oxygen-free copper conductors maximize conductivity
  • Low DC resistance and capacitance—even over long runs
  • Sequential foot markers indicate cable remaining on the spool
  • Pulls and strips easily, reducing installation time
There's no reason to install performance-degrading inferior speaker cable in your home theater or whole-house audio system. Low cost, fully optimized Wired Home audiophile grade speaker cable is the better option! Wired Home's fine copper wire strands minimize capacitance that causes low frequency losses, and each insulated conductor is twisted tightly in pairs to reduce high frequency attenuation caused by excessive inductance.This tight twist also results in a rounder cable profile, making the product much easier to pull around sharp-cornered studs or through conduit. Wired Home in-wall cable features a smooth, easy to feed, tube-style outer jacket for easy installation and wire preparation. UL listed, RoHS compliant, and CL2-rated (temperature rated to 75° C).
Specifications: • Individual conductor: 41 x 30 AWG • Individual conductor overall diameter: 2.5 mm • Overall cable diameter: 6.70 mm • DCR: 0.88 ohms/100 meters • Cable dispensed from a plastic spool.
  • Cable Rating UL Listed,CM Rated,CL2 Rated
  • Wire Gauge14 AWG
  • # of Conductors2 Conductor
  • Jacket ColorWhite
  • Length100 ft.
  • BrandWired Home
  • Model52142H9A
  • Part Number101-207
  • UPC844632071379
  • Product CategoryIn-Wall Speaker Wire
    (4 Reviews)
  • Weight5.85 lbs.
View similar products to the Wired Home 52142H9A 14/2 In Wall Speaker Wire Cable CL2 100 ft.
in the In-Wall Speaker Wire product category.
Wired Home 52142H9A 14/2 In Wall Speaker Wire Cable CL2 100 ft. is rated 4.5 out of 5 by 4.
Rated 5 out of 5 by from Great WireRan about 70 feet of this from my attic down to my basement. Easy to run and not too stiff. Great stuff
Date published: 2013-10-14
Rated 4 out of 5 by from High Quality Wire For In-Wall RoutingThis is high quality wire. The 14GA is good for higher power outputs and is Class 2 for routing through walls.I found it very easy to strip. Just hold the wires and pull the sheath back by hand and trim it off. Don't try to use a knife to strip it unless you want to cut the individual wire's sheaths.Very easy to pull and doesn't sag much between wall studs. If you are using this for anything other than in-wall wiring you have the wrong wire.Good product, good price. What more could you want?
Date published: 2011-01-20
Rated 4 out of 5 by from Great economy speaker wireWorks great and is an easy pull. Used for a customers rear speakers. Does just what a speaker wire is supposed to do... deliver uncolored power to the speakers!
Date published: 2009-11-30
Rated 5 out of 5 by from Great ValueEverything I expected. Great value for the price.
Date published: 2009-02-05
  • 2016-02-13T07:04CST
  • co_hasreviews, tv_0, tr_4
  • loc_en_US, sid_101-207, PRD, sort_mostRecent
Is this wire twisted pair?
Asked by: CCPD
Yes it is twisted.
Answered by: Keith P
Date published: 2012-03-12
  • 2016-02-13T07:58CST
  • loc_en_US, sid_101-207, PRD, sort_recentQuestionsFirst
