Wired Home 3359AD0E RG-59/U Solid Copper Coaxial Cable + 18/2 Siamese 250 ft.
Brand:|Model: 3359AD0E|Part # 101-112
CCTV camera installation can pose some unique installation challenges, if you use the wrong cable. The 339ADOE 250 ft. cable features a solid copper center conductor that is ideally suited for critical video from high resolution surveillance cameras.
  • 22 AWG solid copper center conductor
  • 95% coverage tinned copper braid
  • 125% coverage Mylar foil
  • 18 AWG 2-conductor power cable attached
  • UL, C-UL listed and CMG rated
  • Spool-in-Box payout system
CCTV camera installation can pose some unique installation challenges, if you use the wrong cable. The solid copper center conductor within this RG-59/U cable is ideally suited for critical video from high resolution surveillance cameras. The tinned bare copper braid provides 95% coverage and provides an effective path to transmit RS-422/485 and other camera control protocols, while a 25% overlapped Mylar foil bonded to the dielectric provides 100% shield protection from EM and RF interference. UL listed and CMG rated for use within walls. 250 ft. and 500 ft. put-ups. The two-conductor 18AWG power cable is attached in a Siamese construction allowing you to essentially pull two cables at one time. The power cable can provide a low loss path for 12 VDC as well as 24 VAC. The package was designed with ease of installation in mind. The spool-in-box payout system virtually eliminates performance robbing cable kinks during installation. And if you prefer the use of a wire rack our spool can be quickly removed and "racked-up" on a traditional cable caddy.
  • Cable Rating CMR Rated,UL Approved
  • Coaxial Cable TypeRG-59/U
  • Special FeaturesSiamese with 18/2
  • Jacket ColorBlack
  • Length250 ft.
  • BrandWired Home
  • Model3359AD0E
  • Part Number101-112
  • UPC844632081699
  • Product CategoryCamera Video Cables & Wire
  • Weight16 lbs.
View similar products to the Wired Home 3359AD0E RG-59/U Solid Copper Coaxial Cable + 18/2 Siamese 250 ft.
in the Camera Video Cables & Wire product category.
