Wired Home 3206BF0A Dual RG-6/U Quad Shield Coax Cable 100 ft.
Brand:|Model: 3206BF0A|Part # 101-149
Wired Home quad shield RG-6/U dual cable provides an added defense against performance-degrading interference. Each of the paired cables' construction consists of a copper-clad steel 18 AWG center conductor with a 60% coverage aluminum braid over 125% overlapped foil, plus a second 40% aluminum braid over 125% overlapped foil!
  • Paired design -- install two cables in one pull
  • The preferred A/V cable for inhospitable environments
  • Four layers of shielding reject EM and RF interference
  • 18 AWG copper-clad steel center conductor for maximum durability and signal purity
  • Great for creating custom length A/V cables
  • UL, C-UL listed, and CMG rated to meet applicable standards
  • Sequential foot markers indicate cable remaining on the spool
It is often necessary to run cable through electrically noisy locations. Fluorescent lights, motors, computers, and a myriad of other electronic devices used in offices, homes, commercial, and industrial environments generate massive amounts of EM and RF interference that manifest themselves in signal as audible hum or fuzzy video. Wired Home quad shield RG-6/U dual cable employs premium materials and four layers of shielding to ensure the best possible transmission of signal. The paired "Siamese" construction speeds installation of multiple runs.
Tough outer jackets and copper-clad steel 18 AWG center conductors make this paired cable ideally suited for antenna, cable television, and satellite television installations where harsh surroundings are a concern. This product may also be used to create high performance, custom length composite and component video cables, as well as RCA audio patch cables. Each cable features a 60% coverage aluminum braid over 125% overlapped Mylar foil plus a second 40% aluminum braid over 125% overlapped Mylar foil provide greater shielding than standard RG-6/U. UL listed and CMG rated for use within walls.
Specifications (each cable): • Center conductor: 1.02 mm dia. copper-clad steel • Dielectric: 4.57 mm dia. foamed PE • Inner shield: Aluminized Mylar foil with 60% coverage 80 x 0.12 mm dia. aluminum braid • Outer shield: Aluminized Mylar foil with 40% coverage 48 x 0.12 mm dia. aluminum braid • Nominal impedance: 75 ohms • Velocity of propagation: 82% • Capacitance: 53.1 pF/meter • Nominal attenuation: 21.6 dB/100 meters @ 1 GHz • Overall diameter: 7.62 mm • Cable dispensed from a plastic spool.
  • Cable Rating CMR Rated,UL Approved
  • Coaxial Cable TypeRG-6/U Quad Shield
  • Jacket ColorBlack
  • Length100 ft.
  • BrandWired Home
  • Model3206BF0A
  • Part Number101-149
  • UPC844632071317
  • Product CategoryRG-6 / RG-59 / RG-58 Coaxial Cable
  • Weight8.2 lbs.
View similar products to the Wired Home 3206BF0A Dual RG-6/U Quad Shield Coax Cable 100 ft.
in the RG-6 / RG-59 / RG-58 Coaxial Cable product category.
