Wired Home 3106BF0A RG-6/U Quad Shield Copper Clad 100 ft.
Brand:|Model: 3106BF0A|Part # 101-141
Wired Home quad shield RG-6/U cable provides an added defense against performance-degrading interference. The cable's construction consists of a copper-clad steel 18 AWG center conductor with a 60% coverage aluminum braid over 125% overlapped foil, plus a second 40% aluminum braid over 125% overlapped foil!
OUT OF STOCK
Due In: 3/3/2016
List Price$19.99
You Save41%
$11.77
Buy 4+$10.70
Part # 101-141
  • The preferred A/V cable for inhospitable environments
  • Four layers of shielding reject EM and RF interference
  • 18 AWG copper-clad steel center conductor for maximum durability and signal purity
  • Great for creating custom length A/V cables
  • UL, C-UL listed, and CMG rated to meet applicable standards
  • Sequential foot markers indicate cable remaining on the spool
It is often necessary to run cable through electrically noisy locations. Fluorescent lights, motors, computers, and a myriad of other electronic devices used in offices, homes, commercial, and industrial environments generate massive amounts of EM and RF interference that manifest themselves in signal as audible hum or fuzzy video. Wired Home quad shield RG-6/U cable employs premium materials and four layers of shielding to ensure the best possible transmission of signal.
A tough outer jacket and copper-clad steel 18 AWG center conductor make this cable ideally suited for antenna, cable television, and satellite television installations where harsh surroundings are a concern. This product may also be used to create high performance, custom length composite and component video cables, as well as RCA audio patch cables. A 60% coverage aluminum braid over 125% overlapped Mylar foil plus a second 40% aluminum braid over 125% overlapped Mylar foil provide greater shielding than standard RG-6/U. UL listed and CMG rated for use within walls.
Specifications: • Center conductor: 1.02 mm dia. copper-clad steel • Dielectric: 4.57 mm dia. foamed PE • Inner shield: Aluminized Mylar foil with 60% coverage 80 x 0.12 mm dia. aluminum braid • Outer shield: Aluminized Mylar foil with 40% coverage 48 x 0.12 mm dia. aluminum braid • Nominal impedance: 75 ohms • Velocity of propagation: 82% • Capacitance: 53.1 pF/meter • Nominal attenuation: 21.6 dB/100 meters @ 1 GHz • Overall diameter: 7.62 mm • Cable dispensed from a plastic spool.
  • Cable Rating CMR Rated,UL Approved
  • Coaxial Cable TypeRG-6/U Quad Shield
  • Jacket ColorBlack
  • Length100 ft.
  • BrandWired Home
  • Model3106BF0A
  • Part Number101-141
  • UPC844632071270
  • Product CategoryRG-6 / RG-59 / RG-58 Coaxial Cable
    (3 Reviews)
  • Weight4.05 lbs.
Wired Home 3106BF0A RG-6/U Quad Shield Copper Clad 100 ft. is rated 4.3333 out of 5 by 3.
Rated 5 out of 5 by from Great RG-6 cable!!Very very nice cable for the money! Great cable for using as either cable TV throughout the house or running it from the attic antenna to the TV. I think the cable is very flexible and bends very easy and is great for either short or long runs. Don't bother getting a cheap flimsy cable, get this one you wont regret it.
Date published: 2010-01-18
Rated 3 out of 5 by from Well shielded, not flexible but good price.Much bang for the buck to be sure! This cable is really thick. With the quad shielding it is thicker than most others but still fits the standard compression connectors just fine. Did I mention that it is thick? Would be good for long outdoor runs where high tensil strength would be needed. Not real flexible for short runs. The plastic spool that it's wound on broke in shipment then the other end broke when I flopped it on the bench. Much better if they would have used a metal spool!
Date published: 2009-03-17
Rated 5 out of 5 by from Way cheaper than a retail store.I used this quad sheild to run a dtv reciever in my attic. Its probably a 50ft. run through some potentially noisy enviroments. The picture quality is as good as any of the other tvs in the house.
Date published: 2009-02-05
  • 2016-02-11T06:57CST
  • co_hasreviews, tv_0, tr_3
  • loc_en_US, sid_101-141, PRD, sort_mostRecent
