Wired Home 3106BC0Y RG-6/U Copper Clad Al Braid 500 ft.
Brand:|Model: 3106BC0Y|Part # 101-129
An 18 AWG copper-clad steel center conductor makes this RG-6/U cable strong and resilient to adverse outdoor conditions common with permanent digital cable, satellite, and antenna installations. Copper-clad steel also reduces cable kinks during cable pulls, saving installers time and money.
List Price$64.99
You Save40%
$39.11
Buy 4+$35.55
Part # 101-129
  • 18 AWG copper-clad steel center conductor offers increased cable strength
  • 60% coverage aluminum braid with 125% coverage Mylar foil
  • UL, C-UL listed and CMG rated
  • Spool-in-Box payout system
  • Sequential foot markers indicate cable remaining in the box
RG-6 is a staple of home, commercial, and industrial RF distribution systems. An 18 AWG copper-clad steel center conductor makes this RG-6/U cable strong and resilient to adverse outdoor conditions common with permanent digital cable, satellite, and antenna installations. Copper-clad steel also reduces cable kinks during cable pulls, saving installers time and money. A 60% coverage aluminum braid shield over 125% aluminized Mylar foil provides 100% shield against EM and RF interference. UL and C-UL listed; CMG rated for use within walls. In addition to being used as RF signal cable, this RG-6/U performs well enough to be used for custom length composite video, component video, and RCA audio cables. See the related items listing for easy-to-use connectors. Packaging was designed with ease of installation in mind. The spool-in-box payout system virtually eliminates performance robbing cable kinks during installation. If a traditional cable caddy is preferred, the spool can be quickly removed.
Specifications: • Center conductor: 1.02 mm dia. copper-clad steel • Dielectric: 4.57 mm dia. foamed PE • Shield: 125% coverage aluminized Mylar foil and 60% coverage 80 x 0.12 mm dia. aluminum braid • Nominal impedance: 75 ohms • Velocity of propagation: 82% • Capacitance: 53.1 pF/meter • Nominal attenuation: 21.6 dB/100 meters @ 1 GHz • Overall diameter: 6.86 mm.
  • Cable Rating CMR Rated,UL Approved
  • Coaxial Cable TypeRG-6/U
  • Jacket ColorBlack
  • Length500 ft.
  • BrandWired Home
  • Model3106BC0Y
  • Part Number101-129
  • UPC844632071218
  • Product CategoryRG-6 / RG-59 / RG-58 Coaxial Cable
  • Weight17.35 lbs.
