101-131_ALT_0
Wired Home 3106BC0U RG-6/U Copper Clad Al Braid 1000 ft.
Brand:| Model: 3106BC0U
An 18 AWG copper-clad steel center conductor makes this RG-6/U cable strong and resilient to adverse outdoor conditions common with permanent digital cable, satellite, and antenna installations. Copper-clad steel also reduces cable kinks during cable pulls, saving installers time and money.
  • 18 AWG copper-clad steel center conductor offers increased cable strength
  • 60% coverage aluminum braid with 125% coverage Mylar foil
  • UL, C-UL listed and CMG rated
  • Spool-in-Box payout system
  • Sequential foot markers indicate cable remaining in the box
101-131
Weight: 32.05 lbs.
IN STOCK
List Price$123.99
You Save46%
$66.36
Buy 4-up$61.01
Part # 101-131
RG-6 is a staple of home, commercial, and industrial RF distribution systems. An 18 AWG copper-clad steel center conductor makes this RG-6/U cable strong and resilient to adverse outdoor conditions common with permanent digital cable, satellite, and antenna installations. Copper-clad steel also reduces cable kinks during cable pulls, saving installers time and money. A 60% coverage aluminum braid shield over 125% aluminized Mylar foil provides 100% shield against EM and RF interference. UL and C-UL listed; CMG rated for use within walls. In addition to being used as RF signal cable, this RG-6/U performs well enough to be used for custom length composite video, component video, and RCA audio cables. See the related items listing for easy-to-use connectors. Packaging was designed with ease of installation in mind. The spool-in-box payout system virtually eliminates performance robbing cable kinks during installation. If a traditional cable caddy is preferred, the spool can be quickly removed.
Specifications: • Center conductor: 1.02 mm dia. copper-clad steel • Dielectric: 4.57 mm dia. foamed PE • Shield: 125% coverage aluminized Mylar foil and 60% coverage 80 x 0.12 mm dia. aluminum braid • Nominal impedance: 75 ohms • Velocity of propagation: 82% • Capacitance: 53.1 pF/meter • Nominal attenuation: 21.6 dB/100 meters @ 1 GHz • Overall diameter: 6.86 mm.
  • Cable Rating CMR Rated,UL Approved
  • Coaxial Cable TypeRG-6/U
  • Jacket ColorBlack
  • Length1,000 ft.
  • BrandWired Home
  • Model3106BC0U
  • Part Number101-131
  • UPC844632071225
  • Product CategoryRG-6 / RG-59 / RG-58 Coaxial Cable
    (1 Reviews)
  • Weight32.05 lbs.
View similar products to the Wired Home 3106BC0U RG-6/U Copper Clad Al Braid 1000 ft.
in the RG-6 / RG-59 / RG-58 Coaxial Cable product category.
Wired Home 3106BC0U RG-6/U Copper Clad Al Braid 1000 ft. is rated 4.0 out of 5 by 1.
Rated 4 out of 5 by from coax itself is easy to work with, poor dispenserCoax is easy to work with but I cant seem to get a box delivered without damage to the spool, great idea spool just needs beefed up or packing material in the spool area for protection in shipping. Just a double box doesnt help
Date published: 2009-01-25
Customer projects that include: Wired Home 3106BC0U RG-6/U Copper Clad Al Braid 1000 ft.
