Wired Home 3106BC0A RG-6/U Copper Clad Al Braid 100 ft.
Brand:|Model: 3106BC0A|Part # 101-125
An 18 AWG copper-clad steel center conductor makes this RG-6/U cable resilient to adverse outdoor conditions common with permanent digital cable, satellite, and antenna installations. A 60% coverage aluminum braid shield over 125% aluminized Mylar foil provides 100% shield against interference.
List Price$17.99
You Save50%
$8.95
Buy 4+$8.13
Part # 101-125
  • 18 AWG copper-clad steel center conductor offers increased cable strength
  • 60% coverage aluminum braid with 125% coverage Mylar foil
  • UL, C-UL listed and CMG rated
  • Spool-in-Box payout system
  • Sequential foot markers indicate cable remaining on the spool
RG-6 is a staple of home, commercial, and industrial RF distribution systems. An 18 AWG copper-clad steel center conductor makes this RG-6/U cable strong, and resilient to adverse outdoor conditions common with permanent digital cable, satellite, and antenna installations. Copper-clad steel also reduces cable kinks during cable pulls, saving installers time and money. A 60% coverage aluminum braid shield over 125% aluminized Mylar foil provides 100% shield against EM and RF interference. UL and C-UL listed; CMG rated for use within walls. In addition to being used as RF signal cable, this RG-6/U performs well enough to be used for custom length composite video, component video, and RCA audio cables. See the related items listing for easy-to-use connectors.
Specifications: • Center conductor: 1.02 mm dia. copper-clad steel • Dielectric: 4.57 mm dia. foamed PE • Shield: 125% coverage aluminized Mylar foil and 60% coverage 80 x 0.12 mm dia. aluminum braid • Nominal impedance: 75 ohms • Velocity of propagation: 82% • Capacitance: 53.1 pF/meter • Nominal attenuation: 21.6 dB/100 meters @ 1 GHz • Overall diameter: 6.86 mm • Cable dispensed from a plastic spool.
  • Cable Rating CMR Rated,UL Approved
  • Coaxial Cable TypeRG-6/U
  • Jacket ColorBlack
  • Length100 ft.
  • BrandWired Home
  • Model3106BC0A
  • Part Number101-125
  • UPC844632071195
  • Product CategoryRG-6 / RG-59 / RG-58 Coaxial Cable
    (1 Reviews)
  • Weight3.25 lbs.
View similar products to the Wired Home 3106BC0A RG-6/U Copper Clad Al Braid 100 ft.
in the RG-6 / RG-59 / RG-58 Coaxial Cable product category.
