Wired Home 3106AD0Y RG-6/U Solid Copper Tinned Braid Coaxial Cable 500 ft.
Brand:|Model: 3106AD0Y|Part # 101-105
A solid copper center conductor within Wired Home's RG-6/U cable offers the perfect pathway for high performance signals transmitted and received by multi-LNB satellite and digital cable systems. Additionally, Wired Home's RG-6/U can be terminated to make custom, premium A/V patch cables.
  • 18 AWG solid copper center conductor optimizes signal transfer
  • 95% coverage tinned copper braid and 125% coverage Mylar foil reject interference
  • UL, C-UL listed, and CMG rated to meet applicable standards
  • Spool-in-Box payout system with sequential foot markers to indicate cable remaining in the box
Don't compromise on audio/video cable construction! The added capacity of HDTV channels available from digital cable and satellite makes it necessary to reconsider the type of coaxial cable used for installations. Poor quality wire causes a higher DC voltage drop along the cable length. This limits channel bandwidth, which results in a less than predictable performance that potentially creates service calls.
The solid copper center conductor within Wired Home's RG-6/U cable is the perfect signal path for high performance signals transmitted and received by satellite and cable receivers. The tinned copper braid provides 95% coverage and is also ideally suited for surveillance cameras that transmit data over the shield. Aluminized Mylar foil is bonded to the dielectric (125% coverage) to provide 100% shield protection from EM and RF interference. UL and C-UL listed; CMG rated for use within walls.
Additionally, Wired Home's RG-6/U can be used to make high performance custom length composite, component, stereo audio, and subwoofer patch cables when terminated with Wired Home's RCAX-AU audiophile-grade RCA connectors.
Specifications: • Center conductor: 1.02 mm dia. solid copper • Dielectric: 4.57 mm dia. foamed PE • Shield: 125% coverage aluminized Mylar foil and 95% coverage 168 x 0.12 mm dia. tinned copper braid • Nominal impedance: 75 ohms • Velocity of propagation: 82% • Capacitance: 53.1 pF/meter • Nominal attenuation: 21.6 dB/100 meters @ 1 GHz • Overall diameter: 6.86 mm.
  • Cable Rating CMR Rated,UL Approved
  • Coaxial Cable TypeRG-6/U
  • Jacket ColorBlack
  • Length500 ft.
  • BrandWired Home
  • Model3106AD0Y
  • Part Number101-105
  • UPC844632071102
  • Product CategoryRG-6 / RG-59 / RG-58 Coaxial Cable
    (1 Reviews)
  • Weight22.7 lbs.
View similar products to the Wired Home 3106AD0Y RG-6/U Solid Copper Tinned Braid Coaxial Cable 500 ft.
in the RG-6 / RG-59 / RG-58 Coaxial Cable product category.
